10K mod screw up?
Old Dec 21, 2009 | 07:23 PM
drivembig's Avatar
drivembig
10K mod screw up?
I was working on the 10k mod. I installed a 14.7 combo and liked the performance and decided to try a 15.6. I ran this from the grey/blue to the grey/red wire.
I pulled up to a stop light and the truck died. I got it fired back up and pulled into a gas station for some diesel fuel. After filling up I started the truck and it started surging really bad.
I shut it down and got out and pulled the mod back off because this is the only thing that I had done. Then the truck has a CEL, but is running. It's down on power now and still surges.
At idle the truck will fluctuate from 500 to 1000 rpm and while going down the road sometimes it seems that it's shutting down.
When I start the truck if I don't wait for the WTS light to go off it's really bad. If I wait then it just surges as described above. The CEL comes and goes, but I haven't gotten the code yet.
Just wondering if anyone has had any experience with this?
Maybe the IPR damaged, HPOP maybe?
Any suggestions would be greatly appreciated.
Old Dec 21, 2009 | 08:02 PM
fordpride's Avatar
fordpride
i did the same thing i pulled the mod and cleared the code and it was fine my codes were p1212 injector pressure low or delete p0344 CPS
Old Dec 21, 2009 | 08:04 PM
c00nhunterjoe's Avatar
c00nhunterjoe
i dont like doing the mod with the wires hooked up the way you did. when hooked up inline as i do it there are posted dyno results of 35 hp and 70 ft lbs of torque at the rear wheels. cut the blue and red wire and put the resistor inline
Old Dec 21, 2009 | 11:43 PM
IDMooseMan's Avatar
IDMooseMan
I agree with Joe. I did mine inline (I think he's referring to my dyno testing) and am very happy with how it works.
Do a search for "ICP Resistance Mod Results" to see my dyno testing results.
Old Dec 22, 2009 | 05:15 AM
drivembig's Avatar
drivembig
Could I have damaged anything, because now that the mod has been removed, the truck is still acting up? Thanks for any and all help.
Old Dec 28, 2009 | 10:16 PM
chicagodragon's Avatar
chicagodragon
I did mine the way you did. I ended up putting together a lil box with gang switches so i could try anything from 1k-21k, my truck likes 15k the best. i can chande while driving, witch made it easy to see what combo worked the best, or i can turn it off all together ( stock mode).
Jln2010F250
6.4L Power Stroke Diesel
Oct 1, 2016 08:39 PM
Nick Pigglet Curtis
13
Feb 5, 2016 05:56 PM
jmthunderbirdturbo
1978 - 1996 Big Bronco
31
Aug 24, 2015 01:12 PM
7_three_stroker
20
Dec 5, 2014 09:29 PM
zhilton
Aug 11, 2010 06:09 PM
