ok, ive heard good things about the kingpin 60's im just wondering if during any of those years listed above the leaf spring mounts were in a different position on the 60? thankss
78/79 are narrower spring perches and the center chunk is more towards the middle than the 85* - 97s.
Originally Posted by hav24wheel
85 is a King pin D60 too, Paul.
A 85-97 D60 should easily fit under your pickup, Tim.
I've always read 85.5 was the switch over, like a mid year model - but I have no idea from personal experience. Either way, should get him close enough - hopefully he tell if it's a ttb or a d60
hey guys how much of the ttb crossmember can you cut away? im at a crossroads either dump $$ into this ttb to fix it or spring for a d60, but if a get a 60 right now i wont be able to afford a lift at the same time, well maybe a shackle flip lol, what do you guys say???
Well my crew is on a supercab longbed 4wd chassis. There was a piece of 1/4" plate welded to the frame to "box" it right where the pass side front cab mount is. Well i cut it out to see what the hell is goin on. Apparently some *** has cut the frame top and bottom to fit car manifolds. Then either him or another *** decided to boogerweld weld in patches and box it. Looks like ill grind the welds and reweld. Then ill have some 1/4" bent to make a "c" that fits the inside contour of the frame rails. I think that will take care of the problem.
Meanwhile the idea of a 4 door bronco on 37s with a cummins keeps wondering into my mind.
