Offroad & 4x4
Badazz Pict's (Almost) And Non-Tech Jiberish
  #496
Old 01-28-2010, 10:18 AM
hav24wheel's Avatar
hav24wheel
hav24wheel is offline
General statement....
"More stupid people seem to come out of the wood work every day"
  #497
Old 01-28-2010, 10:21 AM
captain p4's Avatar
captain p4
captain p4 is offline
Originally Posted by tbenks
ok, ive heard good things about the kingpin 60's im just wondering if during any of those years listed above the leaf spring mounts were in a different position on the 60? thankss
78/79 are narrower spring perches and the center chunk is more towards the middle than the 85* - 97s.
Originally Posted by hav24wheel
85 is a King pin D60 too, Paul.
A 85-97 D60 should easily fit under your pickup, Tim.
I've always read 85.5 was the switch over, like a mid year model - but I have no idea from personal experience. Either way, should get him close enough - hopefully he tell if it's a ttb or a d60
  #498
Old 01-28-2010, 10:36 AM
hav24wheel's Avatar
hav24wheel
Well, I have a D60 out of a 85 in my wheeler. Don't remember what part of the year it was made though.
  #499
Old 01-28-2010, 10:38 AM
captain p4's Avatar
captain p4
Hm, maybe I'll try to do some research later on to figure it out for sure.
  #500
Old 01-28-2010, 11:16 AM
Broncoholic1's Avatar
Broncoholic1
Broncoholic1 is offline
Originally Posted by Prozon
What brought that up?
CRNAH found out his Bronco has car exhaust on it. I bet...
  #501
Old 01-29-2010, 02:55 PM
Prozon's Avatar
Prozon
Prozon is offline
I wish he would elaborate lol.
  #502
Old 01-29-2010, 07:44 PM
tbenks's Avatar
tbenks
tbenks is offline
Thumbs up
hey guys how much of the ttb crossmember can you cut away? im at a crossroads either dump $$ into this ttb to fix it or spring for a d60, but if a get a 60 right now i wont be able to afford a lift at the same time, well maybe a shackle flip lol, what do you guys say???
  #503
Old 01-30-2010, 01:22 AM
Prozon's Avatar
Prozon
Prozon is offline
Go for the D60. Your going to put putting just as much money into fixing the TTB that you could be putting towards more important things.
Why do you want to cut away the TTB crossmember? Are you referring to a SAS or do you just feel like hacking away at your truck? O_o
  #504
Old 01-30-2010, 12:05 PM
tbenks's Avatar
tbenks
tbenks is offline
lol, everyone says the ttb crossmember gets in the way of the differential and that you have to trim it to make the solid axle fit
  #505
Old 01-30-2010, 01:17 PM
Prozon's Avatar
Prozon
Prozon is offline
Ah! So your referring to the SAS. Well you can notch out what you need to so the driveshaft/axle will fit fine, or you can do what most do.
Replace it. :P
  #506
Old 01-30-2010, 01:26 PM
Broncoholic1
Loose the TTB & swap a 60 into it.
  #507
Old 01-30-2010, 02:40 PM
NW 150's Avatar
NW 150
NW 150 is offline
what do you guys think about ground hawgs on a dd, offroading sometimes in mud and on trails
  #508
Old 01-30-2010, 03:14 PM
crazyredneckanyhow's Avatar
crazyredneckanyhow
crazyredneckanyhow is offline
Well my crew is on a supercab longbed 4wd chassis. There was a piece of 1/4" plate welded to the frame to "box" it right where the pass side front cab mount is. Well i cut it out to see what the hell is goin on. Apparently some *** has cut the frame top and bottom to fit car manifolds. Then either him or another *** decided to boogerweld weld in patches and box it. Looks like ill grind the welds and reweld. Then ill have some 1/4" bent to make a "c" that fits the inside contour of the frame rails. I think that will take care of the problem.
Meanwhile the idea of a 4 door bronco on 37s with a cummins keeps wondering into my mind.
  #509
Old 01-30-2010, 03:19 PM
tbenks's Avatar
tbenks
tbenks is offline
just to double check, all i would need is the axle, the steering linkage, and have my font driveshaft shortened? right?
  #510
Old 01-30-2010, 04:37 PM
alpha/omega's Avatar
alpha/omega
alpha/omega is offline
I dont think I can handle your questions on ANOTHER project.
Quick Reply: Badazz Pict's (Almost) And Non-Tech Jiberish
