SPindle Help Please!!!
Old Dec 20, 2009 | 11:02 AM
uncwgrad1's Avatar
uncwgrad1
I have a 2001 V8 Eddie Bauer 2wd Explorer that the outer wheel bearing failed on the drivers side and has fused to the spindle. What do I do?
HELP!!!
Old Dec 20, 2009 | 07:14 PM
steve(ill)'s Avatar
steve(ill)
you bust it up to get the hub off, then use a die grinder with a 4 inch cutting disc to grind a slot in the inner race, then pound a chisle into the crack and spread it to pull it off. or grind two slots 180 degrees apart and pop it off. file the bad spot on the spindle.
Old Dec 20, 2009 | 07:21 PM
uncwgrad1's Avatar
uncwgrad1
I've cut through and it won't budge. Looks like it is fused to the spindle.
Old Dec 20, 2009 | 08:15 PM
MikeVT's Avatar
MikeVT
If its friction welded to the spindle you will have to replace the assembly. Not to bad a job but not cheap.
Old Dec 21, 2009 | 09:26 AM
steve(ill)'s Avatar
steve(ill)
you can cut into 2-3 pieces then chisel off each piece. if it has really welded itself on, you probably have an under size diameter where the bearing sets and will need a new spindle anyway.
Old Dec 21, 2009 | 10:55 AM
54Guy's Avatar
54Guy
Don't forget to cehck with an auto wrecker for a replacement spindle, it might be WAY cheaper than one from the dealer. Or maybe find one on ebay.
Old Dec 21, 2009 | 11:06 AM
uncwgrad1's Avatar
uncwgrad1
Thanks for the replies! I laready called the local salvage yard to get a new knucle and rotor/hub. I figured the inside of the rotor is trashed
jsnbuck
Aug 15, 2013 04:32 PM
colt1221
Dec 15, 2012 09:43 AM
rb21747
Dec 3, 2009 02:46 PM
RhinoScores
1978 - 1996 Big Bronco
Mar 9, 2009 06:29 AM
kvoigt11
Dec 28, 2008 05:08 PM
