transmission trouble!!
Old Dec 19, 2009 | 10:07 PM
Allspade's Avatar
Allspade
I have a 1996 F-150, it will shift very harh and my overdrive light starts flashing once it slams into gear. at times i can be driving down the road and my rpms reach 5000 before shifting into second, i also can have my foot on the gas pedal steady and it will all of a sudden act like its in neutral and then it slams into second. my overdrive light starts flashing and engine light came on. i have taken it in for the check engine light and it was a speed sensor i replaced that and the fluid and the problem is still their. I am in school for Automotve but just havent taken the automatics class yet. Someone help!!!
Old Dec 20, 2009 | 12:06 AM
Beechkid's Avatar
Beechkid
Did you check for codes? and has the trans been serviced within 50,000 mile?
Old Dec 20, 2009 | 12:22 AM
Allspade's Avatar
Allspade
The only code that showed up was P0500 (speed sensor). I have changed that and still the problem is still their. I have changed the fluid 18k miles ago. my OD lights still flashing and check engine light is sitll on.
Old Dec 20, 2009 | 05:44 AM
tseekins's Avatar
tseekins
Veteran: Coast Guard
You should re-post this in the 1987-1996 forum, you'll get more help.
Tim
Old Dec 20, 2009 | 07:55 AM
stephen.osborne1's Avatar
stephen.osborne1
This is the wrong forum for this posting, but have you checked the Manual Lever Position Sensor? (MLPS). It's on the driver's side of the E4OD (which I assume is your trans). Sometimes the electrical connection on these gets some crud in there and needs to be disconnected and sprayed with electrical parts cleaner. If this doesn't work, the MLPS might need to be replaced. I think they are around 65 bucks if I recall correctly.
Old Dec 20, 2009 | 09:35 PM
tsd98's Avatar
tsd98
Had a '91 w/the E4OD. Changing MLPS would also be my vote. I had similar symptoms, and the $50 part (back in college days) remedied it. May be a cheap fix if nothing is really mechanically wrong with the trasnmission.
Old Dec 21, 2009 | 08:16 PM
Allspade's Avatar
Allspade
thanks for the advise, will change that and see how that works.
Old Dec 22, 2009 | 07:52 AM
stephen.osborne1
try cleaning the conection like I described first... worked on my old bronco E4OD... saved me 50+ bucks
Old Dec 22, 2009 | 06:01 PM
Allspade's Avatar
Allspade
Ha so i went down town too get some electrical parts cleaner, And on the way down my OD light stoped flashing and check engine light went out, and she shifts normal again. Would i have a short somewhere, pcm, ecm going out???? any ideas????
campbell99
Oct 28, 2023 08:42 AM
Zapp911
Oct 11, 2022 03:32 PM
Fefanatic
Large Truck
Dec 11, 2016 01:11 PM
Black_6.0
Aug 10, 2015 05:57 PM
tim_30043
Mar 28, 2003 07:16 PM
