oil bypass systems
He also runs AMS oil.
He has a super doodie 7.3, but same thing.
Anyways. Setup uses a stock filter and an AMSoil filter.
He said he replaced stock filter at 20k miles. Then changed the oil after 50k miles and sent it in for testing with the results being the oil was still good to use. But he changed it and all the filters anyways.
Boy oh boy. I hope I can get that many miles.
"stand alone BP"
A--Back to the sump?
or
B--Back to the stream for usage?
Mine is A, to the sump and the return fuel line with
shutoff valves. About every 8k i pump about 2qts into the
tank. Been doing this for 130k. Have gone as far as 30k
without and oil change! (oil testing)
Total cost to run 30k was about $300/325? IIRC
It puts me at an oil change every other fuel filter.
Bill
I repeated to him when He told me about it "bypass filter" but being a stubborn old man, he had no clue what I was talking about.
But he had the results with the remote 2 filter system.
Says you can change the filters without loosing to much oil as well, which is good IMO, so you can keep a good change on the stock filter and let the small particulate filter do less work and keep up good flow.
Remember, when you are using a kit/setup like this to get high mileage out of your oil, you must use a synthetic properly, as in, you must flush the oil system of all the dino oil, due to it being a contaminate. AMSoil also sells a flush you run in the system. I'm not sure how it works yet. I was looking in my book about it, now i'ma do some reading online.
I'm going to throw in rotella t syntheitc here for this next oil change here shortly, and run that untill I pick up the AMSoil kit and oil. Then hopefully I'll reduce my oil costs, cause the oil changes are kicking my ***. And for 500 dollars, you can have the AMSoil Kit, unless I find somebody who gets a better discount. 10 oil changes is easily 500 dollars. So. Go figure?
I've already changed my oil 4 times since june when I baught my truck. And I'm only spending 53-65 dollars a change with rotella.
http://www.amsoil.com/bypassfilters/...3L_Sanchez.pdf
Here are some installation pictures.
No punching holes in your pan.
That is a different system I wouldn't advise. This is the way to go here IMO.
I'm looking for a link so I can post the correct unit for our truck and get some sorta price figure for anyone figuring to do this as well.
Maybe clay can get them in for us at a decent price.
Here is the system for our truck.
By-Pass Filters and Mounting Systems
Its saying 372$. I was told 500.
If its 372 retail, then woot.
First I have run a Frantz TP filter. TOO SMALL! Don't work on a 14 quart system! Just doesn't don't bother.
I am now running a stand alone Amsoil Bypass. Seems to be working good. Not even sure how long I have been running the same filter. I need to check it too see if its still flowing. Good set up. I don't go extra miles cause I notice changes in Idle and power when I get too many miles on the oil. I also still just run Rotella 15w40.
Now for the amsoil warning. DON'T Do NOT DON't Ever Never ever! Run the Amsoil dual filter unit that moves the full flow stock oil filter. Just don't do it! The stock filter is rated to flow 32 gallons a minute the lines provided at least in the past with the amsoil dual full flow/bypass kit are not big enough to flow that kind of oil.
When it comes to extending drain intervals beyond the oil manufatures recommendations. I only have three things to say about that:
Test the oil, Test the oil, Test the oil.
I'll get under there and look for the bypass ports, but I don't remember ever seeing these.
Could somebody post some pictures on it?
Thanks for the info tim. I am asking the guy i'm talking about with this what you were talking about.
I remember reading on BITOG that there was flow problems with the old bmk16 system.
