New problems after heavy pull.
Old Dec 18, 2009 | 10:07 PM
oldbird1965's Avatar
oldbird1965
Its located under the hpop, sticks out towards the fuel filter. Yes, they are expensive but a lot of times its just the O rings on it are bad or that tin nut on the end is loose. It takes a big socket (can't remember the size) to get it out. The one replacement O ring is split, when I bought one I thought I had a bad one, lol. If you do remove the IPR, take the tin nut off and slide the next section off. Then you need a deep dish socket.
Old Dec 18, 2009 | 10:22 PM
c00nhunterjoe's Avatar
c00nhunterjoe
the correct o-rings from international are 19 dollars a set. thats the most common problem based on your current concern
Old Dec 18, 2009 | 11:30 PM
strokin'_tatsch's Avatar
strokin'_tatsch
yep this just about has to be IPR o-rings. they sell just the o-rings at ford or international. get some and replace them. the o-rings are cheap.
Old Dec 18, 2009 | 11:35 PM
c00nhunterjoe
not guranteed as i have seen injecotr o-rings do the same thing, but the ipr o-rings are far more common in this case
Old Dec 18, 2009 | 11:46 PM
95_Dually's Avatar
95_Dually
The cool thing is it threw a CEL. That will give you a good idea as to where the problem lies. A lot of times we don't get the CEL.
Old Dec 18, 2009 | 11:49 PM
c00nhunterjoe
yeah but i bet it has a ton of codes in it now as he went unplugging all kinds of stuff...lol, still wouldnt hurt to pull codes and see if it has any oil codes in it
Old Dec 19, 2009 | 12:12 AM
blue66tang95f150's Avatar
blue66tang95f150
True. So Costco has readers, has anybody seen them? Will they work for our trucks? My partner has one too, but its always nice to have your own equipment.
So this is my theory. The o rings dont leek when it is cold because the oil is thick and slow, however as the oil warms up. It gets thin, enabling it to slide past the o rings easily. Is that correct?
Old Dec 19, 2009 | 12:16 AM
c00nhunterjoe
that pretty much sums it up, also the cold orings are stiffer then the warm ones
Old Dec 19, 2009 | 12:19 AM
95_Dually's Avatar
95_Dually
Joe, you are correct about unplugging all of those sensor.
Blue- just borrow your buddys and check it out. You may need to clear the codes and wait for the CEL to pop again.
Old Dec 19, 2009 | 06:24 AM
yoslick's Avatar
yoslick
I gotta ask, did you check the oil level after that hard run? definately sounds oil related (IPR or otherwise) also whats the level in the HPOP when it won't restart??
Old Dec 19, 2009 | 11:34 AM
blue66tang95f150
The oil was fine. I didnt check the level in the HPOP. How do i do that, undo that little plug on the top?
Old Dec 19, 2009 | 01:03 PM
c00nhunterjoe
i doubt its drained teh resevoir. he said if it sits for a few hours it fires right up
Old Dec 19, 2009 | 05:12 PM
  #28
95_Dually's Avatar
95_Dually
Definitely a temp related problem or a big coincidence. Have you read the codes yet?
Old Dec 19, 2009 | 10:25 PM
  #29
blue66tang95f150
Yeah i read the codes today. It had no codes. I talked to international and they wanted me to plug off one bank of injectors from oil. So i took it out warmed it up and plugged off the passenger side oil line. It then fired up on the drivers side bank. So they thought for sure it was injector o rings. So I spent the better part of today putting injector o rings in the passenger side. It started and ran fine till I shut it off at home again. Still no start. Next I am going to try and get o rings for the IPR. Ford nor international had any. I really hope it is the IPR o rings, other than that I have no clue. I am getting very frustrated, I need this truck everyday for work and this really throws a wrench in that. This is just fueling my light duty diesel hating streak I have been on.
Old Dec 19, 2009 | 10:32 PM
  #30
blue66tang95f150
Do you have the international part number? They said they cant get them separately from the IPR?
I would have tried these o rings first but I cant seem to get my hands on any till next wednesday, however I need my truck now.
