VIN/Data Plate Decode Help, Please
Old Dec 16, 2009 | 05:51 PM
Blackfoot Big Block's Avatar
Blackfoot Big Block
My "donor" truck arrived and I'm curious what it has for equipment
The VIN is:F25SRY86223
Color:YZ Body:CU4 Trans:G Axle:22
7900 1977 71
Some of the characters are tough to read so there may be a mistake or two. For example in the VIN I'm not sure if it is an "8" or a "B".
Thanks in advance!
Old Dec 16, 2009 | 07:12 PM
maskedman's Avatar
maskedman
I will try to help you with the basic code and serial number.I am sure others will chime in with the body,paint, and axle codes.F25SRY86223 breaks down like this: F25 is F250 2wd,S is the engine designation which translates to 400cid,R is the assembly plant which in this case is San Jose,Ca.Y86223 is part of the consecutive serial number run for or part of that production year.Hope I have helped you out some.
Old Dec 17, 2009 | 12:34 PM
Blackfoot Big Block
maskedman,
Thanks for the VIN help.
I'm still looking for help with the dataplate. Or if someone could give me a link to a data plate decoder for a 1977 pickup that would be fine as well.
Old Dec 20, 2009 | 09:35 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Blackfoot Big Block
F25SRY86223 Color:YZ Body:CU4 Trans:G Axle:22 // 7900 1977 71
F25 = F250 2WD Pickup.
S = 400 2V
R = San Jose CA Assembly Plant
Y86223 = 1977 / Numerical Sequence of Assembly (Serial Number)
YZ: Y = Jade Metallic // Z = Copper Metallic
CU4: CU = Tan Vinyl & Tan Cloth ~ Ranger XLT // 4 = Styleside Pickup, Bench Seat
G = C6 Cruise-O-Matic
22: Dana 61 / 3.07-1 / non Limited Slip / 5300 lb. Rear Axle Capacity
7900 lbs. Gross Vehicle Weight Rating
1977
71 = Los Angeles (SoCal) Ford District Sales Office, where the original selling dealer ordered the truck from.
Old Dec 20, 2009 | 10:01 AM
Blackfoot Big Block
Thanks Bill,
I have never heard of the Dana 61 and just Googled it. Interesting that it was manufactured so that a lower than 3.54:1 (lower numerically) ring and pinion set could be offered.
The lowest you could get in a Dana 60 being 3.54:1.
Does anybody think this somewhat unusual axle has any value?
Old Dec 20, 2009 | 11:17 AM
fordtech08's Avatar
fordtech08
if you look at the front of an LMC truck catalog it tells you the break down/ vin decode
Old Dec 20, 2009 | 11:18 AM
NumberDummy
Thanks Bill,
The lowest you could get in a Dana 60 being 3.54:1 thru 1980.
Beginning in 1981, Ford offered a 3.33-1 ratio in Dana 60's w/ or w/o Limited Slip. Good luck finding one...or the 3.54-1 as everyone is looking, few are finding any.
Old Dec 20, 2009 | 01:13 PM
Blackfoot Big Block
If that's the case I would think a 3.07:1 might be attractive to someone.
This truck has the Camper Special emblems (well actually one as the other is MIA) and perhaps that's all it has, not the "goodies" that are in the package.
I'm surprised (if it does have that option package) that one could get a 3.07:1 axle in a vehicle specifically made for hauling.
Was the Camper Special (Not the Super Camper Special) available in a four wheel drive?
PW01
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Feb 22, 2017 12:34 PM
matt2491
Dec 9, 2015 04:02 PM
Burlcojoe
Jun 8, 2014 08:31 PM
58f350guy
Oct 21, 2012 03:45 AM
onekwikhd
1966 - 1977 Early Broncos
Aug 20, 2009 10:33 PM
