Refueling '76 F250
Old Dec 14, 2009 | 02:00 PM
gprich9's Avatar
gprich9
Angry Refueling '76 F250
I recently took ownership of a 1976 F250 and am having a heck of a time filing it up at the gas station. I can only let the fuel trickle into the tank because if I even go halfway with the fuel nozzle the gas just pours out. This truck doesn't have the fuel doors like my 1977 F150 had.
Is there anything I can do to remedy this?
Glen
Old Dec 14, 2009 | 02:04 PM
kentuckycrew's Avatar
kentuckycrew
if im not mistaking There should be a hoseclamp holding the filler neck up to the bed. Look to make sure that it has not broke. If it is it could let the neck drop down and make filling up dificult.
Old Dec 14, 2009 | 02:37 PM
SNSTER's Avatar
SNSTER
also check and make sure the vent hose is not clogged
Old Dec 14, 2009 | 06:15 PM
Jermafenser's Avatar
Jermafenser
Replace the fuel filler hose and vent. Be sure to tape them together along the entire length.
Old Dec 19, 2009 | 02:08 PM
gprich9's Avatar
gprich9
I really appreciate you three's suggestions. I will look into those.
Glen
Old Dec 19, 2009 | 11:51 PM
decaruby's Avatar
decaruby
I too just bought one of the new old trucks and realized that until I get around to replacing the filler hoses that I really have to lean on the nozzle to get a good seal, but I still loose a little fuel. The original hose tends to collapse and the replacement job is a real PITA.
Old Dec 20, 2009 | 01:28 PM
mabigredtruck's Avatar
mabigredtruck
mines the same way (75 f250), drives me crazy but it ain't changing. i'm pretty sure the pump nozzles back in the day were curved just a bit different than they are now. sometimes if i hold the pump at just the right angle i can let it flow otherwise i stand there forever pumping 10 bucks worth
Old Dec 20, 2009 | 01:31 PM
SNSTER's Avatar
SNSTER
that is how mine acted then I cut the vent hose to see of that helped and it fills just as fast as any other vehicle I own now
Daniel92f250
Dec 12, 2013 04:43 PM
clee2
Oct 18, 2013 08:22 PM
colemanw
Aug 18, 2011 04:58 PM
J and J
Apr 28, 2011 05:29 PM
smokinLUV
1997 - 2003 F150
Aug 10, 2008 07:46 PM
