We have a U13 roadster and are trying to find out who owned it before us and where it was registered. Does anyone know of a free VIN check that takes the 11 number VIN? All I'm finding is the 17 digit check. Thanks in advance for any help....
Welcome to FTE
The 11 digit Bronco VIN, when decoded, only gives the series, engine code, assembly plant code and the numerical sequence of assembly (last 6 digits).
Depending on the year, you may be able to get a copy of the original build sheet from martiauto.com. There is a charge for this info.
The Bronco's Warranty Plate has other info, including the DSO code, that when decoded, will tell which Ford district sales zone office the Bronco was originally ordered from.
Example: DSO: 71 = Los Angeles.
Post the VIN and all the codes, I can decode all of it.
FYI - The build sheet is available from Ford for free and you can request it online. I got the one for my 2001 F350 in just a couple of days; the sheet for my 57 Bronco took a few weeks.
