ignition lock problem
Old Dec 16, 2009 | 04:57 AM
gafftbk's Avatar
gafftbk
1999 F250 light duty 120000 miles. The end of the ignition lock broke of so I removed it but I also had to remove the bearing cap, bearing, and the gear in order to get the piece that was broke off. I reinstalled everything the way i thought it was suppose to go but it won't start. Could I have put the gear or bearing in incorrectly? When I turn the key forward I don't believe it is going all the way into the run position. 1 because it doesn't start and two i can't get the ignition lock back out. Does anyone have a picture of the correct alignment of the bearing and the gear.
thanks
tonkyman
Aug 9, 2025 12:20 PM
Kwikkordead
141
Apr 26, 2020 07:10 AM
Red-head
Nov 28, 2012 04:45 PM
jack3
Feb 26, 2004 03:20 PM
CTX5500
Electrical Systems/Wiring
Aug 10, 2001 09:21 PM
