Sponsored by: Auxito
4.6L problems
Old Dec 15, 2009 | 07:12 AM
MEFFORD's Avatar
MEFFORD
4.6L problems
i have a 98 f150 with the 4.6L. it blew up and i'm trying to rebuild another one to put in it but everytime i get o number 3 and 7 sometime 2 and 6 i try to spin the motor to finish putting the rest in the motor locks up solid. any ideas? i've tried everything had the rods honed even torquing them down to 30. please help thanks
Old Dec 15, 2009 | 12:49 PM
toadady's Avatar
toadady
sounds like you're out of time,
Old Dec 15, 2009 | 06:48 PM
MEFFORD's Avatar
MEFFORD
i haven't put the motor together all the way so timing is not an issue. i'm just putting the rods on the crank making a short block.
Old Dec 15, 2009 | 07:21 PM
1975IH200's Avatar
1975IH200
Are you sure you have the correct chankshaft?
Too much "throw" will cause this.
Can you determine where the interference is?
Old Dec 15, 2009 | 09:40 PM
MEFFORD's Avatar
MEFFORD
its all the same parts that came in the motor i just tore it down to refresh all new bearings and bolts, rings gaskets the works. and going back together its doing this.
Old Dec 15, 2009 | 10:12 PM
toadady's Avatar
toadady
is the back of your crankshaft hitting the engine stand?
Old Dec 16, 2009 | 07:15 AM
MEFFORD's Avatar
MEFFORD
no its in the same spot it was when i pulled it apart
triguy450
1997 - 2003 F150
Jan 23, 2013 11:03 AM
rrumba
Jun 8, 2009 11:32 PM
Pro725
1997 - 2003 F150
Dec 7, 2008 12:54 AM
chad007
1997 - 2003 F150
Oct 6, 2005 10:35 PM
mrmicrometer
Modular V8 (4.6L, 5.4L)
Aug 29, 2002 03:56 PM
