4.6l windsor
Old Jun 7, 2009 | 11:37 PM
rrumba's Avatar
rrumba
4.6l windsor
question:
Will a 4.6l windosor motor from a 1992 marquis work in a 98 expedition if i swap out heads and intakes?
Old Jun 8, 2009 | 07:07 AM
Johnny Langton's Avatar
Johnny Langton
Originally Posted by rrumba
question:
No,the 91-'92 model modular blocks used the old 5.0L bellhousing pattern.
JL
Old Jun 8, 2009 | 03:32 PM
rrumba's Avatar
rrumba
thanks for the quick reply.
can i use a romeo block with everything else from the Windsor engine? I cannot seem to locate one by me in buford, ga and the romeo engines are plentiful.
Old Jun 8, 2009 | 10:44 PM
Johnny Langton
Any Romeo from '94-present will bolt up to the trans,motor mounts,etc. There are a handful of differences between Windsors and Romeos that can be a hangup, but it's nothing that will keep you from using a Romeo in place of a Windsor.
JL
Old Jun 8, 2009 | 11:32 PM
rrumba's Avatar
rrumba
that is promising. now the million dollar question is what are the littlet hangups that i would need to be concerned with? the engine that is in the expy now had the oil pump fail and engine locked up. i tried to turnit by the harmonic balancer forward and back but it would not budge and it overheated. the minute it happened and i lost oil pressure at 70mph i turned off the key and got over to the side of the road. i plan on using all other parts with the exception of the lower end, block, crank, pistons, rings and rods. if all of those items from a romeo will work and i can use the heads from the windsor that i had pressure tested, cleaned, shaved, new valves and valve job that would be ideal.
so again, what little things would i need to look out for or ensure that i get correct from the begining as you have mentioned?
chad007
1997 - 2003 F150
Oct 6, 2005 10:35 PM
johnfretz
Modular V8 (4.6L, 5.4L)
Aug 5, 2004 09:43 PM
SHartman
1997 - 2003 F150
Nov 9, 2002 11:43 PM
BrandonJ
Feb 3, 2002 11:02 PM
