No Start !!!!!!
Old Dec 19, 2009 | 01:44 PM
ThinkBlue's Avatar
ThinkBlue
And Yes I do have fuel ...
Old Dec 19, 2009 | 01:48 PM
ThinkBlue's Avatar
ThinkBlue
Im starting to hate Holley 4 bbl carb. #080457S
http://www.oreillyauto.com/site/c/de...PartType=C0261
Old Dec 19, 2009 | 01:57 PM
marks69's Avatar
marks69
sounds like the carb's plugged up. try pouring some carb cleaner into the fuel intake, let it sit for a few days then try to start. make sure you pump the gas a bit when you do. if that doesn't fix it your up for a rebuild on the carb
Old Dec 19, 2009 | 01:58 PM
marks69's Avatar
marks69
i had that problem with the holly's. fixed it by going with edelbrock.lol
Old Dec 19, 2009 | 03:05 PM
ThinkBlue's Avatar
ThinkBlue
Ive done that in past and yielded temporary results... Ive tooken it off now and guttin' it out see what went wrong. Ive made so many adjustments and had running for a good while then shortly goes into F.U. mode and doesnt turn over or when it does it stalls on accel or idles then stalls. Moved the screws exactly a turn or a turn and a half, moved the Idle adjustment to screw to the right place and still the next day or so nothing . Here goes nothing.
Old Dec 19, 2009 | 03:07 PM
ThinkBlue's Avatar
ThinkBlue
Which model adapts directly over the type of manifold im running with? Because im strongly considering getting one in the near future if this rebuild doesnt go.
Old Dec 19, 2009 | 03:37 PM
marks69's Avatar
marks69
i'm running the edelbrock manifold so i could go either way. what type of manifold are you running?
Old Dec 19, 2009 | 04:16 PM
Chucky Babe's Avatar
Chucky Babe
well i just got a holley 650 4 barrel double pumper before my problem and i like it but iv had limited experience with carbs
Old Dec 19, 2009 | 06:05 PM
ThinkBlue's Avatar
ThinkBlue
Im not sure but i know its a single plane spread bore has the the firing order stamped on it...I dont see any other Manufacturer name on it..Could it be factory? Is there another way to specify who made it?
Old Dec 19, 2009 | 06:06 PM
ThinkBlue's Avatar
ThinkBlue
Likewise thats why Im diving headfirst, getting in there and doing it for a change.
Old Dec 19, 2009 | 06:07 PM
ThinkBlue's Avatar
ThinkBlue
Would a worn out spring in the float bowl chamber cause a stall? especially on accel?
Old Dec 20, 2009 | 11:53 AM
ThinkBlue's Avatar
ThinkBlue
checked primary resistance on Igniton Coil found at OL= 10K ohms + {NFG } but secondary resistance at 8 k ohms wtf? but oh well at least I know my coil is crapping out to saturation. now on to the carb rebuild...
MurderedoutF2
6.4L Power Stroke Diesel
Apr 13, 2008 11:14 AM
Markvtwin
May 4, 2003 11:28 AM
1968F250LWB
Jan 5, 2003 05:55 AM
garypettengill
Nov 16, 2002 04:01 PM
Thudpucker
May 11, 2002 10:34 AM
