diff suggestions
Old Dec 13, 2009 | 05:15 PM
zxwut?'s Avatar
zxwut?
diff suggestions
I'm looking for suggestions from people with experience with different manufacturers for a LS in my 95 F250. It's axle code 35, so an open 10.25 with 4.10's. Who are you using and where'd you buy it? Thanks.
Rob
Old Dec 13, 2009 | 07:46 PM
Linemo's Avatar
Linemo
depends on what you want the ford lockers are quiet and work good but dont hold up as well to big tires Detroit Lockers are very tough but noisier when they lock/unlock I am running 285/75/16's and am getting ready to regear and install a locker !A good place to start is Randy's Ring and Pinion on the web good prices and selection !! good luck
Old Dec 13, 2009 | 07:59 PM
zxwut?'s Avatar
zxwut?
To reiterate, I don't want a locker, I want limited slip.
Old Dec 13, 2009 | 08:16 PM
94MustangGT's Avatar
94MustangGT
What do you think about this?
Detroit Locker 915A550 - Eaton Detroit Truetrac Differentials - Overview - SummitRacing.com
Old Dec 13, 2009 | 08:28 PM
zxwut?'s Avatar
zxwut?
I was under the assumption that the Detroit lockers locked the rear wheels when one started to slip. Am I wrong and the Detroit locker is a LS?
Old Dec 13, 2009 | 09:08 PM
Hitokori's Avatar
Hitokori
it is like a limited slip it pops when u are turning when they are on the front idk about the rear ones ive always had strait posi in them... if u were to get a locker i would go with the ARB air locker
Old Dec 13, 2009 | 11:08 PM
94MustangGT
The Detroit Trutrac is the LS, while the Detroit Locker is the true automatic locker.
Old Dec 13, 2009 | 11:15 PM
zxwut?'s Avatar
zxwut?
Thanks. That's what I wanted to know.
Old Dec 14, 2009 | 06:26 AM
TexasGuy001's Avatar
TexasGuy001
I like the Auburn LS. I will never own another locker. I had one and it was not in the truck very long.
Old Dec 14, 2009 | 09:33 AM
hav24wheel's Avatar
hav24wheel
Repack a factory LS for it. You can make them grab pritty hard. Or I would suggest a regular locker. Takes a little bit to get use to, but they will last a long time. If you do get a LS. Get a gear drivin one like the Truetrac, that way you never have to put new clutches in it.
Old Dec 14, 2009 | 09:42 AM
Conanski's Avatar
Conanski
I like the Trac-Loc too, it's simple, cheap to rebuild, and adjustable depending how tight you pack it. I have installed a couple Powertrax lockers in open diff carriers and got an exact 50% failure rate, 1 worked perfectly and 1 didn't at all and had to be removed.
Old Dec 14, 2009 | 10:24 AM
njtinman2's Avatar
njtinman2
i wont put a locker on a street truck they drive funny in turns. i would pick a ls. my old bronco with a locker broke to many axles
Old Dec 14, 2009 | 10:31 AM
zxwut?'s Avatar
zxwut?
Rob
Yeah, that.
Old Dec 14, 2009 | 10:53 PM
TexasGuy001
I also like the idea of rebuilding the factory traction lock. Thats what I did several years ago. You can get rebuilt kits for not much money and you can add a couple of clutch discs and make them tighter.
JaySVX
Oct 22, 2014 06:59 PM
OARfan
Oct 24, 2009 01:28 PM
TommyR
Modular V10 (6.8l)
May 5, 2009 04:13 AM
Soldierwithav10
Modular V10 (6.8l)
28
Apr 6, 2007 09:47 AM
BagStroke
Mar 21, 2004 10:06 PM
