7.3 help
Old Dec 13, 2009 | 11:21 AM
jd4020's Avatar
jd4020
7.3 help
I just bought a 97 f250 with 7.3 has new tranny under warranty the tranny was not shifting at high acceleration tranny shop said tranny is fine but wont shift because of lack of power computer code shows exaust back pressure circuit tube and sensor coming from manifold were pluged i cleaned what is the proper name for this sensor i thought map sensor but it does not look like the map sensor on part pictures could it be somthingelse any help would be much appreciated
Old Dec 13, 2009 | 11:52 AM
IDMooseMan's Avatar
IDMooseMan
Welcome to
Sounds like you're asking about the Exhaust Back Pressure Sensor. The Exhaust Back Pressure Valve (on the turbo) is used to help warm up the engine. (I keep mine unplugged - two-wire connector to the right of and under the turbo) I don't think it has anything to do with how the tranny shifts.
What code did they tell is being set?
Old Dec 13, 2009 | 11:58 AM
Copedawg's Avatar
Copedawg
X2 on Wht Craig said! EPBV, what I I understand if it is stuck closed ya get about 30 MPH then it starts to act like chevy errr mean poop.
WELCOM TO FTE!!! This is the 24/7 proffesional online help site. Hope to see you around and and become apart of our community! Where are you from? and how miles do you have? and what kind of mods do you have???
Old Dec 13, 2009 | 12:01 PM
jd4020's Avatar
jd4020
p0470 exaust back pressure sensor circuit this is the code it shows
Old Dec 13, 2009 | 12:07 PM
Hussler's Avatar
Hussler
Here is a diagram of the engine sensors on the 7.3, well most of them ...
Old Dec 13, 2009 | 12:17 PM
Copedawg's Avatar
Copedawg
If I send you my e-mail addy will you send me that please?
Old Dec 13, 2009 | 12:20 PM
IDMooseMan's Avatar
IDMooseMan
This code is set when the EBP sensor malfunctions.
If you've cleaned the tube and where it's installed, I'm gonna take WAG and say you need a new EBP sensor.
Old Dec 13, 2009 | 12:22 PM
IDMooseMan's Avatar
IDMooseMan
Hey Copedawg,
Right-click on the photo and select 'Save picture as' to save it to your computer.
Old Dec 13, 2009 | 12:34 PM
Copedawg's Avatar
Copedawg
Will do craig! Thanks!
Old Dec 13, 2009 | 04:38 PM
IDMooseMan's Avatar
IDMooseMan
You're welcome. Glad I could help.
Bigtruc
Jun 24, 2012 07:56 PM
bigbadpowerstroke
Jun 16, 2010 07:02 PM
tradergem
Oct 7, 2007 11:01 PM
larry1211
Oct 5, 2007 11:56 AM
