1995 F250 Engine Code Help!
Old Jun 13, 2010 | 05:35 PM
bigbadpowerstroke's Avatar
bigbadpowerstroke
Exclamation 1995 F250 Engine Code Help!
I am interested in buying a 1995 f-250 powerstroke 7.3. Truck is in decent shape and runs good. The transmission was rebuilt by amco and has a three year warranty. The transmission shifts a little hard especially from 1-2 shift. I used my edge programmer to run a diagnostic check and i get a code P0107- BARO/MAP SENSOR- Low voltage detected! The gentleman that is selling the truck said that the sensor is out and makes the transmission shift hard. Is is this true or do you think there is transmission problems? What does the MAP sensor do? Please help me so i can make a decision to buy this truck.
Thankyou
Luke
Old Jun 13, 2010 | 05:38 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
Yep. The P0107 will make the transmission shift hard.
Old Jun 13, 2010 | 05:45 PM
powerstoked!'s Avatar
powerstoked!
the MAP (Manifold Air Pressure) sensor measures the pressure in your intake manifold. It reads the same thing your boost gauge does, if you have one. I know that MAP is tied into how the transmission selects it's shift point at a given throttle position, but don't know why it would make the trans shift harder... very possible though in my head, and cleatus says it does too, so. I would go with, yeah it could be, I can't imagine a MAP sensor costing too much... Might buy one or tell the guy to replace it to be sure, because as im sure you know, you don't want to have to get into these E4OD's... they're spensive
Old Jun 13, 2010 | 06:23 PM
Hussler's Avatar
Hussler
P0107 = Baro sensor signal voltage was less than .04 volts for more than .2 seconds. WAG sensor is either defective or unplugged. Map sensors are very expensive so don't buy one for this code.
Don't know about the shifting issue. I've unplugged my MAP sensor before and it shifts just fine. Never tried unplugging the BARO sensor though.
Old Jun 13, 2010 | 06:33 PM
bigbadpowerstroke
What is the BARO sensor? What does it do? So the MAP sensor and the BARO sensor have nothing to do with hard shifting?
Old Jun 13, 2010 | 07:10 PM
Hussler's Avatar
Hussler
The BARO signal if used to determine altitude to adjust timing and fuel quantity to optimize engine operation and control smoke throughout all altitude conditions.
If the BARO signal is detected out of range by the PCM it will cause the PCM to ignore the BARO and use the MAP signal at low idle as an indication of barometric pressure.
I've never heard of a bad BARO sensor ... always a first time though.
Old Jun 13, 2010 | 07:15 PM
powerstoked!
really? a MAP sensor costs alot? who am I kidding, it's a FORD part, of course it does... I have no idea where the BARO sensor is, but my best educated guess is it's a barometer to measure atmospheric pressure so that the computer can adjust it's fuel program according to altitude change. Have the owner replace it, clear the codes and drive the truck fresh, or price the sensor and take like double off the offering purchase price... take a good look at the rest of the truck though, because if he won't take care of a sensor, then there are some other things probably been neglected... jsut my $.02
Old Jun 13, 2010 | 07:29 PM
bigbadpowerstroke
Is it normal for the transmission to shift hard from 1-2? It feels like if maybe they put a shift kit in it? The rest of the gears are smooth with no slipping. Transmission was rebuilt by amco and is still under warranty. According to cletus he said that code with make it shift hard but what do i need to do to correct the code? Its a 95 f250 supercab 4x4 151000 miles. Hes asking 4,000 truck is in overall decent shape for being 15 yeras old. I just dont want to buy something that is going to be problems i need to make a good decision.
Old Jun 13, 2010 | 07:42 PM
powerstoked!
well, you can clear the code with any scanner and see if it will stay off for a drive cycle to test drive the truck without the code throwing the tranny into safe mode...
And no, it's not normal for a hard shift, these tranny's are actually notorious for disgustingly loose slippy shifts. More like a car trans than what you would expect from a truck trans really... And like I said, take a good look around the truck for leaks, split seals, ball joints, tie rod ends (splits, looseness), drive it and see if there are any wierd noises, drive it around enough to warm the motor up and let it sit idling and check for running leaks, check the valley of the motor for fuel puddling (lifter pump seal fail), i'd check the oil, trans fluid and fuel bowl for fluid color to get an idea of if it's maintained and check the filter in the fuel bowl, check coolant color, power steering fluid color, and the pump for leaks... stuff like that. There are a few weak points with the peripherals on these trucks, but you won't find a more bulletproof motor around. And devilishly good looks as we might all agree upon
Old Jun 13, 2010 | 07:55 PM
bigbadpowerstroke
Ive been reading about the E4OD and i read that sometimes the 1-2 hard shift is cause by the 1-2 accumulator! Could that be the problem? The owner agreed to take back to aamco since it is still under warranty.
Old Jun 13, 2010 | 07:59 PM
powerstoked!
well, i'm no auto tranny guru, but i suppose that could be it... And cool, still under warranty, take her back!
Old Jun 13, 2010 | 10:38 PM
bigbadpowerstroke
so i spoke to the owner of the truck. he is going to take the truck to the transmission shop! but he keeps telling me that the transmission shop and a diagnositc check from a mechanic both said that the faulty sensor causes the hard 1-2 shift. has anyone had this problem or heard of this????
Old Jun 14, 2010 | 09:14 AM
cleatus12r's Avatar
cleatus12r
Butt-Head
The BARO sensor is under the dash above the foot pedals. It IS used for transmission shift pressure functions.
Old Jun 16, 2010 | 05:35 PM
bigbadpowerstroke
Cletus, Owner had the baro sensor replaced and that fixed the hard shifting thanks for your help and everyone else that replied!!!
Old Jun 16, 2010 | 07:02 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
Good to hear.
60DRB
19
Aug 11, 2018 08:14 AM
aclaybor
Feb 3, 2017 01:32 PM
Mwvwaw
Jan 8, 2016 03:05 PM
coreyw2
Dec 5, 2015 04:52 AM
dmonell
Oct 10, 2013 11:42 AM
