Howdy Bro's
My fuel pressure gauge had a dummy spit and was reading zero. So I hooked up my newly acquired AE. (Thanks Clay). Now Im still trying to get my head around what it can do but I cant get a fuel pressure reading through live data. What am I doing wrong ???
Dont know really. The truck was running but it was reading zero. Might of had a foreign body in the line. It runs of the rear port on the fuel bowl. Or it could be a fault within the gauge.
I see you have the CCK. If it is a later model there is an 1/8" NPT plug at the tee. I removed that plug and plumbed my fuel gauge sender
to the tee. That way you are seeing the fuel pressure after feeding the injectors and also post fuel filter. Post filter you won't get debris
in sending unit and a decrease in pressure would indicate time to change filter. Just an idea.
