rail mounted fuel filter
Old Nov 16, 2016 | 02:25 PM
flravem's Avatar
flravem
Hi...I'm TR....Anyone had problem changing the fuel filter on the frame and can't make the drain valve stop leaking?
Old Nov 16, 2016 | 04:25 PM
Iowa Ford's Avatar
Iowa Ford
If you took the drain valve out too far it could have an O-ring that's not sealing up inside. If you mean it keeps running and you can't drain the bowl to change the filter, just loosen the bowl about 3 turns.
Good luck TR....
Old Nov 16, 2016 | 11:55 PM
Dakster's Avatar
Dakster
I almost had to remove the darn bowl all the way before it stopped draining...
Old Nov 17, 2016 | 04:28 AM
bkuuz1's Avatar
bkuuz1
Like others have said, You have to unscrew the hosing several turns after opening the drain or it pulls a vacuum while draining and will drain your fuel tank.
Old Nov 17, 2016 | 08:26 AM
flravem's Avatar
flravem
well I removed the drain plug.....and now it wont seal up......Ford told me you have to buy the pump and filter hsg.........anybody know if the bottom of the filter is available aftermarket?
Old Nov 17, 2016 | 09:18 AM
djousma's Avatar
djousma
the bowl, and drain plug are available separately. what year is your truck?
Old Nov 17, 2016 | 09:21 AM
djousma's Avatar
djousma
Also, if I recall correctly, there are two green orings on the drain plug. you might examine it to make sure they didn't get wrinkled, or pushed out of their grooves
Old Nov 17, 2016 | 09:54 AM
flravem's Avatar
flravem
I have a 2016 F550, The "o" rings and the yellow drain plug look perfect....so I must have messed something up in the hsg
Old Nov 17, 2016 | 10:02 AM
djousma's Avatar
djousma
Check out this thread: https://www.ford-trucks.com/forums/1...l#post16620434
It's my post where I list all three part numbers for my 2016.
Old Nov 17, 2016 | 10:05 AM
flravem's Avatar
flravem
cool.......thanks
djousma's Avatar
djousma
You can get online and verify that those part numbers are correct for your F550. I would assume so, but we all know what that leads too...
Old Nov 17, 2016 | 10:10 AM
flravem's Avatar
flravem
Dave........are these Ford OEM numbers?
Old Nov 17, 2016 | 10:20 AM
djousma's Avatar
djousma
Yes. You can go online at this Ford dealer, and put your year/make/model/vin and cross reference the part numbers to make sure that they are correct for your vehicle.
AutoNation Ford White Bear Lake | Parts & Accessories
Old Nov 17, 2016 | 10:21 AM
djousma's Avatar
djousma
I just went to that Ford site, and they don't have a dropdown for F550, however you may be able to drop your vin number in there to verify.
Old Nov 17, 2016 | 10:23 AM
djousma's Avatar
djousma
Here is FORD's website
FordParts.com Super Duty
