Almost crashed into the garage
Old Dec 12, 2009 | 02:25 PM
JHoffman93's Avatar
JHoffman93
I have a new problem now that the temps are dipping down in the 20's. I drove the truck to work yesterday and several times I had no power brakes. Scarred the poo out of me the first time it did it. Then last night I almost crashed into the garage. This summer I changed the vac pump, master cylinder, calipers, pads and front brake hoses. It is obviously a vac problem but what? I still have normal heater function. Are the boosters known to have problems? I never have been able to lock up the brakes, but from what I am reading that is fairly normal. I don't really want to replace the booster if that is what it is because I'd like to convert over to hydra boost brakes, just don't have the time or money to do that right now. I'm I barking up the right tree in thinking its the booster leaking vac internally? The big vac line coming off the pump looks ok. Maybe I should replace it first just to rule out the cheap and easy fix.
Old Dec 12, 2009 | 03:03 PM
starmilt's Avatar
starmilt
Put a vacumn on it and see where what you have.
Old Dec 12, 2009 | 03:26 PM
PLC7.3's Avatar
PLC7.3
I sent you an email... if you want the vacuum test.
Old Dec 12, 2009 | 03:43 PM
bad12jr's Avatar
bad12jr
mine did the same thing. I just pushed really really hard. It scared me too at first.
Hey PLC would u mind sending me that too?
Old Dec 12, 2009 | 04:36 PM
greywynd's Avatar
greywynd
Sounds like either your booster or your vacuum pump is toasted. If the heater will still change functions (defrost to vent for example) then you have at least some vacuum, as it is vacuum assisted to switch it. Losing that was what clued me into my vacuum pump being toasted a few years ago.
The boosters will also go, in my case I didn't realize the master cylinder had leaked into the booster chamber, so when I changed the master, everything seemed good for a while, until the booster died. They aren't hard to replace, biggest issue is the contortions you have to go through to undo the clip under the dash for the pedal linkage.
Old Dec 12, 2009 | 08:12 PM
JHoffman93's Avatar
JHoffman93
PLC7.3 I didn't get your email. Not sure why. I have a vac guage, I'll see if I can plumb is in and see what the pump is pulling.
Old Dec 12, 2009 | 09:01 PM
87crewdually's Avatar
87crewdually
For a quick test pull the rubber hose off at the pump and see if the pump will suck your finger to the port (with the engine running of course)
Old Dec 12, 2009 | 09:47 PM
JHoffman93's Avatar
JHoffman93
I'll do some investigating tomorrow afternoon and post my findings.
Old Dec 13, 2009 | 12:23 AM
Dave Sponaugle's Avatar
Dave Sponaugle
If you guys send Pete a PM with your direct email addy he can send you the file.
He can not attach a .pdf document to the FTE email.
Old Dec 13, 2009 | 02:11 PM
JHoffman93's Avatar
JHoffman93
Ok, I hooked up a vac guage and the pump is pulling 24 in. at the booster. All the lines appear to be in good condition. Hooking up at the booster and pulling 24 in. seems to tell me that the pump and plumbing to the booster is in good condition. Am I right? What should these pumps be pulling?
Old Dec 13, 2009 | 02:28 PM
Dave Sponaugle
Now if you press the brakes, how low does it go?
And how long to recover?
24" of vacuum is fine.
You also might want to pull one of the block off caps on the vacuum tree and check various positions on the heater control to make sure you don't have a vacuum leak in one of the heater control lines.
Old Dec 13, 2009 | 02:32 PM
JHoffman93's Avatar
JHoffman93
Wont be able to work on the truck more today. But I will hook my guage up to the tree and test heater selection and brakes tomorrow.
Old Dec 13, 2009 | 03:03 PM
JHoffman93's Avatar
JHoffman93
Baby went back to sleep so I went out and did a few more tests real quick. With guage plumbed into the vac manifold operating the heater controls had no effect on vacuum. Stayed steady as a rock. Pressed brake with moderate pressure and vacuum went to about 7 in. recovered to about 15 in and stayed steady. Released brake, vac went to 5 in. and took almost 40 seconds to recover back to 24 in. If I press the bake real hard the vacuum will drop to about 10 and recover up to about 20 and stay steady. Turned truck off and vacuum only dropped about an inch in three minutes. Pressed brake with truck off and vac dropped to 10, when released vac went to zero.
dougbrown
21
Dec 31, 2013 12:14 AM
DBGrif91
19
Aug 11, 2013 07:31 AM
genscripter
18
Jun 28, 2013 04:36 PM
Adam79
Jul 31, 2005 11:21 PM
salewit
Jan 14, 2005 12:23 AM
