adjusting my idle?
Old Dec 12, 2009 | 06:50 PM
Black Smoke '88's Avatar
Black Smoke '88
adjusting my idle?
i have been spending a lot of time working on my truck recently and all my buddies have strokers and one of them has a lope in the idle because he put in the resistor mod. i was wondering if there is any way to make my 7.3 IDI lope when it is at idle. just wondering if it is even possible with my truck. thanks in advance for the help.
Old Dec 12, 2009 | 08:50 PM
IDIDieselJohn's Avatar
IDIDieselJohn
I don't think so, Strokers have engine computers, that's why you can make 'em do more weird things than on an IDI.
Old Dec 12, 2009 | 08:53 PM
Kleenax's Avatar
Kleenax
Now I'm confused..... Why on earth would you want your truck to do that?
Old Dec 12, 2009 | 08:57 PM
87crewdually's Avatar
87crewdually
Yeah Why? If your idle is turned way down it will lope but that's bad for the engine.
Old Dec 13, 2009 | 07:35 AM
9473's Avatar
9473
Lope?.....
Old Dec 13, 2009 | 09:39 AM
dyoung14's Avatar
dyoung14
Originally Posted by 9473
Lope?.....
ever herd a gasser with a cam?
Old Dec 13, 2009 | 09:48 AM
starmilt's Avatar
starmilt
That is a gasser a diesel is not made to run at low idle more so if you have a turbo.
I have worked for people that would fire you if climbed out of a truck without setting the high idle.
Old Dec 13, 2009 | 11:01 AM
87crewdually
Absolutely canned. It's called wet stacking. The engine at low rpm runs so cool the rings don't fully seal and the fuel doesn't completely burn and ends up washing down the lubrication in the cylinders and you get premature ring wear.
Old Dec 13, 2009 | 11:17 AM
starmilt's Avatar
starmilt
I suppose you could always loosen the injector lines until you get the desired sound.lol
Old Dec 13, 2009 | 11:26 AM
9473's Avatar
9473
OK I get, aesthetically pleasing sound kinda thing. Thanks
Old Dec 13, 2009 | 01:03 PM
Black Smoke '88
thats exactly it i was just wondering...if its bad for the engine i wont do it...thank a lot for all the help and insight
Old Dec 13, 2009 | 06:58 PM
dyoung14's Avatar
dyoung14
they do lope big time if you do that trust me, lol i forgot to tighten 4 lines down once, when it fired it was loping like crazy
Old Dec 13, 2009 | 07:03 PM
dyoung14's Avatar
dyoung14
you cant turn the idle screw low enough for it to idle down no matter how far you turn it your still limited by the min/max governor assembly, when i changed and put my 4500rpm spring in i misplaced my low idle spring so i stole one out of a spare pump but i couldnt get it to idle below 1000 rpm, but then i found my old spring and put my low idle spring back in and left the 4500 rpm big spring, and now i have the 550 rpm idle and 4500 rpm rev limit which is just perfect for me
F-250 restorer
27
Jul 18, 2017 07:39 PM
82fordguy
17
Aug 14, 2016 09:27 PM
cuttn4fun
15
Feb 9, 2016 12:07 PM
fordboy300
Aug 9, 2011 02:41 AM
bad12jr
Nov 17, 2009 06:28 PM
