WOW. - 40. What kind of oil are you using at that temp? Why exactly are the Motorcrafts not cutting it? Are those temps requiring extended cranking the batteries can't handle?
A little off topic. What kind of fuel additive are you running in that kind of weather?
Huck,
Thought I would chime in and say I use schaeffers winter in the blue can. I was up in Grand Forks ND on the 8th and it was -30 with the wind chill. I did NOT plug it in and she started and ran fine. I use the red can n the summer. Every tank. Hijack over
i can help out on the Odyssey batteries our reno store should have them.
$$$ but they are good batterys i have installed duel sets in jeeps before.
truckee is a cool place went 4x4 there once (startreck) i think it was called
I'm using the napa premiums. The Napa guy there said they are Interstate batteries and thus far I have not had a problem what so ever at starting up with the temps in the single digits and a wind chill factor of -5
Optima. Run them in my boat. Have left them in & hooked up all winter and they are fine come spring time. Killed many a "All Things Chinese Store" (Walmart) batteries.
