Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
flywheel/clutch
Old Feb 15, 2020 | 09:43 AM
ford300chipper's Avatar
ford300chipper
If I get the 180 tooth ring gear would I be able to switch the ring gear to the 184? Or will the 180 work with my setup and starter? I just assumed since the tooth count was different the flywheel would not work. Thanks for your help, finding this information has been tough!
Old Feb 15, 2020 | 09:52 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Ford said the 180T flywheel replaced the 184T flywheel, said nothing about any other part being replaced. So I would assume the starter etc will work.
I have no specs on the 180T flywheel, so don't know if it's the same diameter as the 184T flywheel or not.
Old Feb 15, 2020 | 09:53 AM
ford300chipper
YOU ARE AWESOME! Thank you for your help! I have been trying to crack this mystery with different parts people for a while!
Old Feb 15, 2020 | 09:55 AM
ford300chipper
Would you be able to give a part number for the clutch kit that would be used with that flywheel?
Old Feb 15, 2020 | 10:07 AM
NumberDummy
I could, but not until later tonight or tomorrow.
Old Feb 15, 2020 | 10:09 AM
ford300chipper
Whenever you can, very much appreciated, seems this information is difficult to come by.
ford300chipper
Jan 26, 2020 04:41 PM
wrongwaypeachfuzz
May 6, 2019 09:45 PM
Damifiknow
Apr 26, 2013 09:51 PM
Broomfieldbum
Sep 5, 2010 04:55 AM
