Explorer wont warm up.
Old Dec 11, 2009 | 07:29 PM
shameless's Avatar
shameless
I have a 2001 explorer, it wont heat up anymore. I drive it for a half hour and it wont heat up, the needle is buried on cold on the gauge, the heater blows cold air, and it has water in it. I did use some stop leak a while back but that was weeks before this all started. Any ideas?
Old Dec 11, 2009 | 07:31 PM
Milwaukee1979F150's Avatar
Milwaukee1979F150
There problem
clean radiators to remove that stop leak. Or get to shop and they will flush it.
Then try change thermostat to 195oF.
Old Dec 11, 2009 | 07:34 PM
shameless's Avatar
shameless
can I flush it myself, and, how hard is it to change a thermostat on these newer motors. last time I changed one was on an 84 S-10 with a 2.8
Old Dec 11, 2009 | 08:36 PM
steve(ill)'s Avatar
steve(ill)
stop leak is good for a hole in the radiator or gasket. one bad thing that can happen is to gum up the thermostat and it will not close all the way. the water pump will circulate water thru the radiator all the time and nver warm up. YOu need to pull the thermostat, clean it out real good, or install a new one. If you leak is now fixed with the stop leak, drain out the rest and refill with clean antifreeze and you should be o.k.
derekb
Jan 31, 2016 05:14 PM
scotty_fred
Dec 1, 2009 12:02 PM
ashley6
Feb 10, 2008 04:20 PM
guy0783
38
Jan 12, 2007 10:17 PM
1984 f-250
Mar 28, 2005 12:04 AM
