sheet metal repairs
Old Apr 25, 2000 | 04:26 PM
BenS's Avatar
BenS
sheet metal repairs
What's the proper way to weld in a sheet metal repair panel?
Old Apr 26, 2000 | 04:28 AM
frankie's Avatar
frankie
sheet metal repairs
i don't know. i wish i did. now that i'm an old man of 51, i now wish i had spent more time in trade school learning body work and painting and such instead of electronics. i just have to have someone else do any welding i need done.
Old May 28, 2000 | 01:32 AM
thrasher's Avatar
thrasher
sheet metal repairs
stitch or spot weld a little at a time do not over heat any one area or you will warp the metal
to fill small holes you can use a piece of copper as a backing for the weld. the weld will not stick to the copper.
Old May 28, 2000 | 02:56 AM
Bob_VT's Avatar
Bob_VT
sheet metal repairs
Glue it in. I recently installed wheel arch panels on one of my Ford trucks and used Body Panel Adhesive. It works. If you search the web you will find sites that have even crash tested panels that were glued on.
It was quicker than welding and there was no panel warpage. It you do insist on welding I would suggest a wire feed welder.
Old May 28, 2000 | 03:01 AM
PetesPonies's Avatar
PetesPonies
sheet metal repairs
THis is true, technology has brought about extremely strong glues. This comes fom the fact that many of todays panels can not be welded on. If you guys have never welded before, I strongly advise you not try it on your truck first. I have done countless vehicle welds on replacement panels and it is not easy. Buy a welding book. Buy a restoration book. Practice first. There are many ways of doing it, butt weld, flange, onerlap etc. There are several welders, MIG or TIG is by far best.
Old May 28, 2000 | 06:39 PM
fndoffrddign's Avatar
fndoffrddign
sheet metal repairs
Mig welder is the way to go. Copper is great cause it doesn't stick but I dout you would need it for body repair work. For small holes i have found perferated (sp?) metal is great cause it holds bondo though the holes in it and is easy to bend in curves..I used it to repair the outside corners of my cab and it was easy to bend it to match the curves.
1976 100 custom...351M...6" suspension lift, 3" body lift...38 super swampers
Old May 28, 2000 | 07:42 PM
fe's Avatar
fe
sheet metal repairs
vidaliaman
15
Jan 14, 2017 04:20 AM
fightlivefree
16
Feb 27, 2016 12:13 PM
72CC428
Nov 7, 2015 06:18 PM
bart f-350
Oct 7, 2015 04:57 PM
oldmerc
Jul 11, 2015 12:21 AM
