coolant filter
Old Dec 10, 2009 | 07:43 PM
wuttrd's Avatar
wuttrd
Thumbs up coolant filter
if you have not done this mod yet you need to bad. i just flushed the system and being courious dumped the filter that i had one for about a month in the mop sink holly s-it lots of gunk !!!!!all gone now!!
Old Dec 10, 2009 | 08:14 PM
indyF-350psd's Avatar
indyF-350psd
you can't fix stupid!
they are sweet arent they? ill never take mine off. good deal.....
Old Dec 10, 2009 | 08:17 PM
big poppa's Avatar
big poppa
Installed one this past summer and I still have decent flow going into the degass bottle but will be pulling the first filter off to see soon what I caught in it. Pics would have been nice, we like pics. Yes, it is a good mod, any extra filtration mod is the way to go.
Old Dec 10, 2009 | 08:19 PM
bigb56's Avatar
bigb56
I can't explain why but I got my truck used, well cared for. I flushed the cooling system really well even opened the block drains, put in Rotella ELC and installed a coolant filter. Changed the filter a few months later and cut the old one open, it was clean as a whistle.
Guess I'm just lucky.
Old Dec 10, 2009 | 08:40 PM
camodown's Avatar
camodown
I wonder if the coolant had silicate drop out or something... Did the gunk look like fine sand?
Old Dec 10, 2009 | 08:56 PM
SpringerPop's Avatar
SpringerPop
Here's the sandy gunk that my first filter collected:
Pop
Old Dec 10, 2009 | 09:07 PM
big poppa's Avatar
big poppa
Pop
Pop, when you took your filter off, did you let the filter sit and dry out or did you dry it out another method ?? I'm going to be pulling mine soon and can opening it..
Old Dec 10, 2009 | 09:27 PM
SpringerPop
I cut the can open with a huge pipe cutter that I have (leaves no "filings").
I cut a 2-liter soda bottle in half to get an open-top container.
I filled the soda bottle half-full with water.
I submerged the filter element in the water.
Stuck my air compressor's nozzle into the inside of the filter element to "backflush" the element.
Removed the element and let the stuff settle in the water for a couple of days.
Poured off most of the water.
Poured the remainder through a coffee filter and let it all dry for a few days.
Brushed it onto a piece of printer paper for the photo you see.
Pop
Old Dec 10, 2009 | 09:34 PM
clem1226's Avatar
clem1226
Thumbs up
Pop
now thats dedication!!
big poppa's Avatar
big poppa
Awesome Pop, will do. I still have somewhat decent flow at idle but it's been in there since the summertime, way past the first 3 month initial change out..thanks again.
Old Dec 10, 2009 | 11:44 PM
spdmpo's Avatar
spdmpo
This reminds me I need to change mine. I've still got that original filter on when I did this in March.
Old Dec 11, 2009 | 07:39 AM
bigb56's Avatar
bigb56
Makes me wonder if my filter did have something in it, I merely cut it open with a cutoff wheel, took a quick look at the element and tossed it.
Was the deposits hard to see before you backflushed it?
Old Dec 11, 2009 | 08:30 AM
kirkharrod's Avatar
kirkharrod
Here's mine:
Old Dec 11, 2009 | 09:45 AM
SpringerPop
kirkharrod,
Looks like you could benefit by having a coolant filter, even with the ELC.
There's still some of that stuff in there eating away at your water-pump seal. You certainly didn't drain it all.
BTW, why DID you drain the ELC?
Pop
Old Dec 11, 2009 | 09:48 AM
SpringerPop
They were there, down in the pleats, but not real obvious.
Pop
lewis racing
Aug 22, 2014 10:50 PM
nico963
Jun 21, 2010 06:35 PM
whporwil
6.4L Power Stroke Diesel
Aug 19, 2009 09:07 PM
rudedogii
1978 - 1996 Big Bronco
16
Feb 9, 2008 10:19 PM
StrokeThis96
Nov 19, 2007 09:46 PM
