Track bar mount broken...
Old Dec 9, 2009 | 06:32 PM
camodown's Avatar
camodown
Hey everyone! I saw a thread a while back about someone who's track bar mount on the axle had broken and I am in a similar situation. Somehow my track bar mount has broken and got smashed, so re welding isn't an option. I tried calling around for a track bar mount but since it is welded to the axle, no one has a replacement part. Does anyone know where to find a new or aftermarket mount?? The salvage yards only want to sell me the whole danged axle....
Old Dec 9, 2009 | 08:03 PM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
Since it is welded on you might be in a pinch.
Old Dec 9, 2009 | 08:07 PM
brwolfjr's Avatar
brwolfjr
Mine snapped off right along the weld on the axle. I had a suspension specialty shop look at it and the owner who has been doing this forever decided welding would be my best bet.
70K miles later it is still good.
Old Dec 9, 2009 | 08:09 PM
spdmpo's Avatar
spdmpo
If you were near me I could weld you up a new one. I'd find an offroad shop/Jeep club and find someone with fabrication skills. A track bar mount is easy for those guys.
Old Dec 9, 2009 | 08:40 PM
camodown's Avatar
camodown
Hey, thanks for the replies... I was hoping the part may be replaceable, but it looks like yall are right and the part is not sold seperately. I am going to stop by our local metal fabrication shop and see what they can come up with tomorrow. I'll update if I find a solid solution as it seems this is fairly commonplace...
Old Dec 9, 2009 | 10:41 PM
BillyBob69's Avatar
BillyBob69
Have them add a "truss" to the mount to make it stronger than OEM
Old Dec 9, 2009 | 11:28 PM
robs01f250's Avatar
robs01f250
yea the fabrication shop seems like your best bet
Old Dec 10, 2009 | 07:08 AM
rpenterics's Avatar
rpenterics
I was the one with the thread awhile back, I'm in the process of getting it fixed now. If you look on Ed's site there is what appears to be a stock replacement available - www.partsguyed.com
I couldn't be sure that was what I needed and since mine can be welded I'm going that route. Hope you're able to get it fixed
Old Dec 10, 2009 | 02:44 PM
camodown's Avatar
camodown
Well, the fabrication shop told me that due to liability concerns, they cannot fix the mount. SO, I went to a different dealer and the mount at the axle is only serviced with part 3010 which is the whole housing. The above posted part seems to be the 5A136 which is not part of the flimsy mount I managed to re break... I am having a truck service center try to fix it tomorrow...Hopefully they can salvage part of it
Old Dec 10, 2009 | 02:51 PM
BillyBob69's Avatar
BillyBob69
I kind of understand where they are coming from but jeez. It shouldn't be that hard to get someone to weld a piece of metal to the axel housing. If they are really that worried about it then they need better welders.
Old Dec 10, 2009 | 02:57 PM
camodown's Avatar
camodown
Yeah, I kind of understand, but at the same time, they fabricate elevator shaft housings, truck racks, bumper protectors, etc, so I'm not sure why they said no. If my MIG hadn't died, I'd wander over to the steel supply here, and do it myself, but, the feed is screwed up and it won't work consistently...
Old Dec 11, 2009 | 06:51 PM
camodown's Avatar
camodown
Well, just figured I'd put a close to this thread. I managed to have the shop hack together a fixed mount, even if it is a bit ugly looking. It have been trussed and although a bit crude looking, gets the job done. I did notice the tie rod had some wear from where it had contacted the old mount on a tight turn, not sure what that was about. At any rate, thanks for the replies, and check your mount carefully for cracks before it breaks off, and if possible, strengthen and box the existing mount, as I feel like the factory mount is too weak...
rpenterics
22
Apr 28, 2014 07:25 AM
Bthutch04
Jan 9, 2013 10:23 PM
MobeyDick
Oct 31, 2010 07:58 PM
389sixpack
May 29, 2007 01:30 PM
mooktank
Offroad & 4x4
Mar 4, 2003 07:25 PM
