Help...2005 excursion seats
Old Dec 9, 2009 | 04:07 PM
wrlc3's Avatar
wrlc3
My seats are pure hell after 2-3 hrs. I have a set of junkyard 06 Lincoln Navigator to put in but I need a wiring diagram of the Nav seats. They are power everything with heat and cool. Any Help out there.
Thanks
Old Dec 9, 2009 | 05:39 PM
katiesdad7's Avatar
katiesdad7
Ditch the Nav seats. Put in a Lazy-Boy. There's enough room!
Old Dec 9, 2009 | 10:30 PM
wrlc3's Avatar
wrlc3
thanks a lot
Old Dec 9, 2009 | 10:51 PM
Paul T's Avatar
Paul T
You might try the Expedition & Navigator forum.
Old Dec 10, 2009 | 06:24 AM
tdappleman's Avatar
tdappleman
Provided you can get them mounted in the truck - I think the heating and cooling mode will be the most difficult. The switches are tied into the climate control unit in the dash - low/med/hi for each mode. On my 03 Expy there was a 30amp circuit for each seat for the power controls and another 30 amp circuit for the heating/cooling. These seats essentially contain a heat pump and draw a considerable amount of power. Once you find the wiring - be careful and make sure you use a good gauge of wire to avoid any issues.
Old Jun 30, 2010 | 09:29 AM
wrlc3's Avatar
wrlc3
Excursion seats
Found 07 Navigator seats. They fit fine with some mounting mods. Added $100 seat heaters and all works well but no memory but Im the only driver so all is good again. Thanks for the replies
1990inline6
Jun 28, 2013 07:37 PM
FrankeeD
Mar 29, 2013 02:11 PM
Jims05Screw
2004 - 2008 F150
Nov 13, 2006 10:52 AM
tcooper3
Apr 3, 2004 01:37 PM
