ABS light
Old Dec 9, 2009 | 11:59 AM
tx fisherman's Avatar
tx fisherman
ABS light
so i had a problem with the speedometer and odometer the ABS light was also on, we replaced the ABS sensor, and the speedometer and odometer started to work again, but the ABS light is still on. i dont know what this might be, or if i shouldnt really worry bout it
Old Dec 9, 2009 | 12:10 PM
Lazy K's Avatar
Lazy K
The ABS light on means that the computer has detected a fault in the system and has disabled the RABS. You will still have fully functioning normal brakes.
Easy things to check are brake fluid level, that both rear brake lights are working properly and that the plug connections at the master cylinder are clean and tight.
Also helps everybody if you post what the truck is.
dannytilton
Sep 8, 2011 07:29 PM
fixitman1310
Mar 20, 2011 10:15 AM
dfarland
Sep 23, 2010 03:06 PM
cassenbl
Sep 1, 2008 06:06 PM
boothtec
Apr 23, 2006 11:27 AM
