Sponsored by: Real Truck
ABS and Speedometer problem
Old Aug 15, 2011 | 06:13 PM
dannytilton's Avatar
dannytilton
I have a 2004 F550 6.0 Powerstroke.The the ABS light is on .
The Speedometer and Odometer come and go.
The speedometer will jump from 0 to 100 and it will add miles while sitting still. where should i start?
Old Aug 15, 2011 | 06:23 PM
Shake-N-Bake's Avatar
Shake-N-Bake
Try replacing the VSS (Vehicle Speed Sensor) located in your rear differential housing. It usually isn't too expensive (around $28-$35) or so.
EDIT: I am assuming the 2004 models are the same as the 7.3 years where the VSS is located in the rear differential. If this is not correct, then someone should be along shortly to let you know where it's located.
Old Aug 16, 2011 | 07:37 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Yep, on top of the rear pumpkin.
Old Sep 7, 2011 | 06:32 PM
dannytilton
turbo want boost
i have a 2004 power stroke 6.0 the turbo want boost until you reach about 3000 rpm
any ideas on what to do.
someone told me:
that the computer should be re programed.
that the blades could be sticking (need ro run it at a high rpm to sling the carbon build up off of the blades.)
it does not report any codes and you can hook a computer to it and make the turbo kick in
Old Sep 7, 2011 | 06:52 PM
Unrealo4's Avatar
Unrealo4
someone told me:
Check you're map sensor hose and the little nipple on you're intake. Also it could be a bad ebp sensor.
Old Sep 8, 2011 | 07:29 PM
Lou Braun's Avatar
Lou Braun
Recommend starting by reading the ABS codes. Without knowing what is triggering that ABS light, you are shooting in the dark. Once you have the error code deciphered, you should be able to isolate the problem.
From your description, I would suspect the rear sensor. If the code supports this guess, replace it and go from there.
The turbo lag issue is a totally different problem. Sometimes just using the truck under varying loads frees up the turbo's unison ring and things run normally afterwards. Worst case is a turbo cleaning.
Lou Braun
cabloom300
Jun 26, 2012 04:18 PM
1976and2001_250
Apr 18, 2011 09:20 PM
99strokun
Sep 25, 2007 09:43 PM
jonnyrocket_70
1983 - 2012 Ranger & B-Series
Aug 21, 2004 06:46 PM
Rangerman255
Sep 18, 2003 07:17 PM
