truck won't start when cold
Old Dec 6, 2009 | 10:35 PM
429PI IN 75 f-100's Avatar
429PI IN 75 f-100
I went to start truck today weather was about 20 degrees cycled glow plugs twice and nothing so ended up cycling the plugs about ten more times and no start then gave up could smell raw fuel, college has no place to plug truck in. truck is 95 with 225,000 miles, has fresh oil, and edge programmer
<input id="gwProxy" type="hidden"><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden">
Old Dec 6, 2009 | 10:54 PM
StrokerJoe's Avatar
StrokerJoe
Put money on it that you have an issue with your GP's or GPR. When was the last time you checked or replaced either one? In temps like that you definitely need the GP's working properly to get these trucks started especially if you don’t have the block heater plugged in. <?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
Old Dec 7, 2009 | 06:41 PM
429PI IN 75 f-100
they were both replaced two years ago, could it be the programmer it locked up pcm this last summer and truck has never started the same after got it unlocked
Old Dec 7, 2009 | 11:14 PM
StrokerJoe's Avatar
StrokerJoe
I doubt it's your programmer. I know people have had issues with Edge Evolution messing up their PCM. Thankfully mine has been good to me. But what you are describing sounds like classic GP or GPR problem. Raw fuel means your injectors are firing. Have you tried starting it with the block heater plugged in for awhile? I've heard of GPR's only lasting people 2 months, and you said yours is 2 years old. As far as lifespan on the GP's it's how much they are used and also what brand you go with too can make a difference. Some of the cheaper one's don't last as long and for sure don't use Autolite. Most people on hear go with the Motorcraft GP's. They seem to hold up the best. A lot people on here opt for the heavy duty Stancor relay part # 586-902 because the OEM replacement ones are prone to wearing out real fast. I’m going with the Stancor for my truck here real soon. Here is one post that talks about it. https://www.ford-trucks.com/forums/822068-glow-plug-relay.html You can search and find other posts that talk it too. One way to quickly rule out the GPR is to run a connection between the two large posts with like a screwdriver for about 30 seconds. If the relay is bad, but your GP are working this will bypass the relay and send power to the GP. Also check out this thread. It has a lot good info about the GP system and diagnostics for it. https://www.ford-trucks.com/forums/424709-glow-plug-gpr-hard-winter-start-and-white-smoke-thread.html<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
Old Dec 8, 2009 | 10:43 PM
429PI IN 75 f-100
thanks for all of the information, dad really thinks that it is the programmer
Old Dec 8, 2009 | 10:46 PM
FARM69's Avatar
FARM69
I don't think there is anything more to add here...
Get the good GP's. It's not worth putting new ones in next year.
Old Dec 9, 2009 | 11:09 PM
429PI IN 75 f-100
what are the best glowplugs for my truck, kind of stuck with a napa and a carquest in are little town and is there any tips or tricks on changing them
Old Dec 9, 2009 | 11:23 PM
MustangMatt96GT's Avatar
MustangMatt96GT
get ZD-11 motorcraft plugs... very easy to replace... takes about an hour...
Old Dec 10, 2009 | 12:08 AM
scatgo's Avatar
scatgo
Or if one of the tips break off and gets stuck in the hole it could be many many hours.
AndeyHall
Jul 4, 2011 07:29 AM
c473
Jul 5, 2010 10:35 PM
JamesHajek
45
Apr 27, 2010 01:58 PM
JamesHajek
Jan 20, 2010 11:51 PM
patrickke
Dec 14, 2009 09:44 PM
