Sensor underneath FICM Harness??
Old Dec 5, 2009 | 06:11 PM
1954oldred's Avatar
1954oldred
06 F350 I removed my FICM after it tested bad, under the FICM harness, there are (3), there is a sensor, what is it?
Old Dec 6, 2009 | 08:34 AM
1954oldred's Avatar
1954oldred
trying to be more clear. The FICM harness has three plugs. The "sensor" under the harness plugs is the one I have a question of. There are three others like the one in question. It may sound dumb, but I'm curious! Thanks.
Old Dec 6, 2009 | 09:22 AM
Gofigurethis_01's Avatar
Gofigurethis_01
Bump
Those would have to be the pass-through connections for the injectors/glow plugs wiring harness(es)?
Old Dec 6, 2009 | 11:05 AM
cheezit's Avatar
cheezit
is it a grey. 2 wire sensor?
if so it's going to IAT2 on the manifold, ECT next to the t-stat, and EOT in the oil cooler
Old Dec 6, 2009 | 11:12 AM
1954oldred's Avatar
1954oldred
Afternoon cheezit, No, it is directly under the FICM Harness. I have already had the IAT2 out to clean it, I'm certain of that. It makes sense to Me that they are the pass through connectors as gofigurethis-01 states. I thank you both for your help!
Old Dec 6, 2009 | 11:15 AM
cheezit's Avatar
cheezit
yes if they are black 4 pin connectors then they are the injector coil coil harness but there should be 4 to a bank.
Punkfish
Sep 2, 2015 02:32 PM
enchanter
May 8, 2013 10:18 PM
OneTon4Fun
Apr 22, 2012 07:31 PM
spindler52
Nov 29, 2011 11:59 AM
KRDiesel
Jul 13, 2010 03:21 PM
