defrost problems
Old Dec 4, 2009 | 04:52 PM
jinklz69's Avatar
jinklz69
defrost problems
1985 f250 7.3 idi navistar diesel. just replaced heater core no more leak. i have everything works, floor vent mix but not defrost it somes out on the floor. any ideas
Old Dec 4, 2009 | 05:07 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
Do you have Factory A/C, or did the truck have Factory A/C at one time?
If the truck doesnt have Factory A/C does it have a standard or deluxe Hi Output heater?
It can be a number of things, but will need to know which system you have...
Old Dec 4, 2009 | 06:22 PM
jinklz69's Avatar
jinklz69
factory ac it has been removed i dont know about standard or ho or not i just got a new heater core and didnt say anything about standard or high output
Old Dec 4, 2009 | 07:31 PM
dustybumpers's Avatar
dustybumpers
the cable from your off/heat/ def has come unhooked.look at the heater box on top of where the heater core goes in from under the hood and make sure the cable is hooked up, and working.
Old Dec 4, 2009 | 07:49 PM
81-F-150-Explorer
If he's still using the Factory A/C heater box, the controls are vacuum operated. One of the vacuum lines could have came unhooked or broke during the heater core install.
Old Dec 5, 2009 | 12:01 AM
jinklz69's Avatar
jinklz69
i will check it out
sunny.richter
Oct 4, 2015 08:32 PM
Copedawg
Aug 17, 2015 05:56 AM
Ford redneck 09
Jan 18, 2015 08:30 AM
Suicidal
1997 - 2003 F150
Jan 14, 2015 10:05 AM
'90-f150-302-5spd
Apr 9, 2010 05:22 AM
