Sponsored by: Auxito
2002 F-150 heat problems
Old Jan 9, 2015 | 03:50 PM
Suicidal's Avatar
Suicidal
Has the 5.4, heat works correctly on panel & defrost select. Anything involved with the floor defaults to the defrost. Also if the selector is on panel sometimes it will switch to defrost when climbing a hill (assuming there's a vacuum change there.) Thanks in advance guys!
Old Jan 9, 2015 | 07:29 PM
vaper's Avatar
vaper
Here you go
https://www.ford-trucks.com/forums/7...xpedition.html
Good luck
Old Jan 9, 2015 | 10:22 PM
steve(ill)'s Avatar
steve(ill)
you have a vacuum leak and the default is to defrost when vacuum is low. As listed on the above link, you may have a cracked vacuum hose on the firewall in front of the glovebox, or more toward the center of firewall (passenger side). Look at the plastic connectors and TEE fittings on the hoses. Remember there is a vacuum accumulator inside the passenger fender, behind the battery. Hoses can pull off, or canister can get damaged in an accident, etc............. If all else fails, you might have an internal leak on the controller on the dash. There are several hoses on the ****. One is vacuum inlet and several hoses out to various control cylinders.. The selector has O-rings between the ports to seal the vacuum... the rings can wear out and leak. Not a big job to replace.
Old Jan 10, 2015 | 07:37 AM
projectSHO89's Avatar
projectSHO89
Do you have a manual or the automatic EATC?
This is a bit more than the common leak in the vacuum supply problem (although that may also be present) as there is an issue with the panel/floor vacuum motor and its panel. If it were solely an issue with the supply, the vent selection shouldn't work at all.
Old Jan 10, 2015 | 11:12 AM
steve(ill)'s Avatar
steve(ill)
possibly vacuum leak on SOME ports of the controller ? Read this link. Not 100% correct, but it should give you an idea of what your looking for.
https://www.ford-trucks.com/forums/8...e-defrost.html
Old Jan 10, 2015 | 12:51 PM
projectSHO89
Maybe, but we don't even knew what control head he has.
Old Jan 14, 2015 | 10:05 AM
Suicidal's Avatar
Suicidal
I'm assuming it's manual. It's a selector ****.
Harley Hill
Oct 19, 2016 05:18 PM
HerbW
1997 - 2003 F150
Jun 4, 2014 08:27 PM
Nick Greer
Aug 2, 2012 08:28 PM
fordmustangfan67
Jul 1, 2012 05:17 PM
jmasie
General Automotive Discussion
Jul 14, 2005 09:33 AM
