How to: Remove Emblems w/ Pics!
Old Dec 4, 2009 | 03:45 PM
4inchlovin's Avatar
4inchlovin
So I was bored at work today and decided i wanted to remove my door emblems. So I did a few searches on here and couldn't find 1 thread that was a good step by step. I am a little over cautious about removing emblems from my truck after my tailgate incident. So I took all the info I found in other threads and used it to my advantage. And here is what I came up with.
What you need:
Alot of people had suggested different types of solvents to use for unsticking the emblem and getting the glue off afterward. I had three available.
In order of popularity in threads:
1. WD40
2. Goo-Gone
3. Simple Green
I used all three.
Set by step.
1. Take WD40 and spray all around the emblem. Let it soak in.
2. Use fishing line in a sawing motion to "cut" the emblem from the truck.
(note: it should not take much to cut through adhesive, if so spray more wd40)
Heres what it should look like after emblem is gone:
3. SOAK left over adhesive with WD40. Take an old gift card and use it to scrape away most of left over adhesive crud. (foamish looking stuff)
(note the wetter the foamish stuff is the easier)
4. Use Goo-Gone AND Simple Green to remover left over glue and dirt.
The dirt ring around it is the hardest part to get off. But it will just need some elbow grease.
LOL!!!
Old Dec 4, 2009 | 03:55 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Good post Nolan. but why are you taking them off? Putting new ones on?
When I took mine off, I used a plastic scraper and just worked it under the emblem and used alcohol to finish the cleaning. I didn't think about the string and WD-40. Good job.
Old Dec 4, 2009 | 04:01 PM
papadelogan's Avatar
papadelogan
Snowboard season cometh..
I still have the "4x4" stickers on the bed & "F250" on the fenders, but thankfully when I bought my truck, there were no emblems on the doors. I like the "clean" look personally.
Old Dec 4, 2009 | 04:11 PM
4inchlovin's Avatar
4inchlovin
I am going to either do the acetone wash on my stock ones or i have some smaller after market ones.
Just a reminder the badges on the fenders and tailgate have pins in them. when you remove them there will be wholes.
Old Dec 4, 2009 | 04:19 PM
PaysonPSD's Avatar
PaysonPSD
FTE Remembers
The 4x4 stickers will pull off as a whole piece if you use a hair dryer to heat them up as you pull. Medium heat to start with and go to high if needed. The paint will just need some light cleaning.
Old Dec 4, 2009 | 06:06 PM
Izzy351's Avatar
Izzy351
I cleaned mine on the truck. They look pretty damn good, if you ask me...
Old Dec 4, 2009 | 06:24 PM
Bergerson's Avatar
Bergerson
You can buy an eraser wheel at any auto body shop or supply store, there about 5 bucks each and one will last you a lifetime unless your doing a ton of them. they will fit any drill and the gunk dirt grime ect comes right off.
carcrafter22
1574
Feb 10, 2022 07:56 PM
jdecker88
The Next Generation
42
Jul 31, 2012 02:00 PM
bigpowerstroke
13
Dec 24, 2010 12:28 PM
suzuki1750
Offroad & 4x4
110
Jul 24, 2009 12:00 PM
X_Hemi_Guy
Jun 5, 2008 09:34 PM
