Oil Change time
Old Dec 4, 2009 | 02:22 PM
twister2gt's Avatar
twister2gt
Oil Change time
Its winter here in kansas for those that dont live here one day is 50 out the next it could be 10. Going to switch to motorcraft filter was thing i should use a 5w-40 Been using 10-40. What do you guys use. This is a 89 F250 with a 351. I could not find a recommended oil in my chilton book.
Old Dec 4, 2009 | 02:31 PM
Hitokori's Avatar
Hitokori
5-20 is recomended i think but i use valvoline full syntetic 10-40 in mine but i live in tennessee
Old Dec 4, 2009 | 02:35 PM
darthice's Avatar
darthice
5w30 is what ford recommends but i use 20w50 in mine but i live in arkansas
Old Dec 4, 2009 | 02:39 PM
Volvo92906's Avatar
Volvo92906
5w-30 is good winter weight oil. Thats what I got in my truck now. It was 27 today. I hate cold and snow. Blah.
Old Dec 4, 2009 | 02:43 PM
Hitokori's Avatar
Hitokori
lol i new it had a 5 and a 0... close enough i guess..
Old Dec 4, 2009 | 06:46 PM
FordGuy91's Avatar
FordGuy91
During the winter months here in Michigan I run 5W-30. Seems to be like a good weight for MI weather.
Old Dec 4, 2009 | 07:10 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
5W- "Winter" @ freezing
40 @ operating temp. 212*F or 100*C, the boiling temp of water.
A lower winter viscosity index will get the oil flowing to the bearings quicker during the critical first seconds of cold start situations.
RotellaT 5W-40 is available in gallon jugs at WallyWorld. Wait for the sales...
Old Dec 4, 2009 | 08:04 PM
unibody62's Avatar
unibody62
I use Amsoil synthetic 5w-30 here in NE Ohio. Amsoil has been around since the early 1970's and is rated best overall. Check out the pour point test and the cold cranking viscosity test as well as all 7 test here https://www.amsoil.com/comparison/motor-oil.aspx . It's pricey, but if you use their filters, it can run up to 25k or 12 months before it's time to change. So that makes it cost effective, not to mention having your oil changes down to yearly instead of 3 months! Also you can become a preferred customer for $20 and save about 25% off of the price.
Old Dec 4, 2009 | 08:15 PM
zxwut?'s Avatar
zxwut?
Am I the only one that likes to change my oil at shorter intervals or 3-4k miles? What if something gets in your oil filter at 1k miles in and you don't change it for another 14k? Plus, doing an oil change gets you in there to do other preventative things that you think about when you're doing it such as ball joints, tie rods, checking for leaks, checking brake and coolant levels, etc.
Old Dec 4, 2009 | 08:29 PM
unibody62's Avatar
unibody62
Oh well, you still gotta check your oil and look under your hood, but it's something you can do when you fuel up. You shouldn't just change it and forget about it.
Old Dec 4, 2009 | 09:25 PM
FordGuy91's Avatar
FordGuy91
Nope you're not the only one. I like to change mine about every 4k miles.
Ultraboy
Feb 1, 2015 04:47 PM
Thumper19
Aug 9, 2012 01:32 PM
ztodd377
Jun 6, 2007 06:42 PM
gtm245
Oil & Lubrication
34
Jun 5, 2004 05:42 AM
Avanti
Oil & Lubrication
Jul 27, 2003 11:00 PM
