what oil do i use?
Old Aug 7, 2012 | 07:39 PM
Thumper19's Avatar
Thumper19
what oil do i use?
I am new to these trucks and I have a 70 f100 with a freshly rebuilt i6 300 with a c6. I am going to be changing the oil and from what i could find people say to use 15w-40 and other say 10-30 or 10-40. Nothing I could find specified if that was for newer or older worn out engines. I assume 10w-30 would suffice but I dont want to be the "***" that assumes.
Old Aug 7, 2012 | 08:10 PM
jacks61ford's Avatar
jacks61ford
I use straight 30w with zinc additive
Old Aug 7, 2012 | 08:13 PM
montana_highboy's Avatar
montana_highboy
I'd recommend Shell Rotella T 15w40, no need for zinc additive if you run a diesel rated oil.
Old Aug 7, 2012 | 11:42 PM
Thumper19's Avatar
Thumper19
In a newly rebuilt motor??
Old Aug 8, 2012 | 02:23 AM
RichS2659's Avatar
RichS2659
The older engines need to use zinc (ZDPP) to prevent excess wear. Modern oils have had it removed by the EPA, and modern engines don't use the older types of lifters and cams which need the zinc. That is why diesel oil still contains zinc. Quaker State makes a 5/10W-30 high mileage oil that contains zinc, besides the Rotella. Search this site and also Google for info on ZDPP.
Old Aug 8, 2012 | 02:26 AM
Thumper19's Avatar
Thumper19
well my next question is then.. if my engine was rebuilt with parts not needing that zinc additive, will there be any ill-affects from using the oil with zinc?
Old Aug 8, 2012 | 04:42 AM
jowilker's Avatar
jowilker
Thumper, We live in a world today with choices and feel good. It makes some folks feel good to spend extra money on oil with additives. While there has been no rising number of failures recorded due to the non use of those oils with additives, some will declare you must use them to run an old engine.
Should you find yourself with extra jingle in your jeans, and you feel better spending it on oil with additives, please do.
Your favorite 10W30 with a good filter on a regular change schedule should prove a good choice too.
John
Old Aug 8, 2012 | 08:51 AM
MIKES 68 F100's Avatar
MIKES 68 F100
Rotella t15w40
is what i am running
Old Aug 8, 2012 | 11:50 PM
orich's Avatar
orich
Originally Posted by MIKES 68 F100
Rotella t15w40
Yup 10-4 on the Rotella 15-40..
orich
Old Aug 9, 2012 | 03:54 AM
willowbilly3's Avatar
willowbilly3
No zinc in the new Rotella I'm told. It's was reformulated in 2009 for low emissions on new diesels and zinc will jack up the particulate filters. Straight from a Dodge tech.
Old Aug 9, 2012 | 08:54 AM
MIKES 68 F100
BUT YOU CAN FIND THE OLD ROTELLA T15W40 AS IT'S NOT A FAST SELLER .
Old Aug 9, 2012 | 10:59 AM
montana_highboy
"No zinc" is a bit of a stretch, but the new formula certaintly contains less zinc than older formulas, due to EPA regulations.
The current CJ-4 rated Rotella contains 1200ppm of zinc, down from a high of 1500-1600ppm of the old CG-4 and CH-4 rated Rotella.
So yes, Rotella's zinc content has taken a hit over the recent years, but it still far exceeds the 800ppm minimum recommended for flat tappet motors.
Old Aug 9, 2012 | 12:59 PM
MIKES 68 F100
thanks Montana didn't know that !!
Old Aug 9, 2012 | 01:13 PM
willowbilly3
Not that I don't believe you but I would like a link to the source of that info. I looked all over Rotella's site and didn't find anything but a big commercial for how great it is, and that 2009 was the year it was re-formulated.
Old Aug 9, 2012 | 01:32 PM
montana_highboy
No problem Mike.
Willowbilly, i don't have a specific link per se, but if you're so inclined you can contact fellow forum member "Bullitt390".
He's a journeyman diesel mechanic who regularly sends in Rotella for oil analysis (Blackstone laboratories i believe, but don't quote me on that).
Anyways, that's where i got the numbers from, i believe they were from early 2012.
collinft
Sep 29, 2011 08:09 PM
ranger rules
General Automotive Discussion
20
Jun 4, 2007 05:23 AM
laswalker
Apr 3, 2006 05:18 PM
aztec12
Oil & Lubrication
Sep 20, 2004 05:55 PM
BigNorm
1978 - 1996 Big Bronco
Apr 2, 2002 10:05 PM
