Free parts
Old Dec 3, 2009 | 07:57 PM
woods's Avatar
woods
Free parts
I have been posting on the FE forum but thought I would add a couple things here.
I'm cleaning the shop and keep finding un needed parts.
Camper Special camper wiring harness that goes from the frame harness to the camper. It is in OK shape but is complete.
Power brake booster and master cylinder off late 60s early 70s Ford truck.
Rebuildable C-6 transmission.FE bolt patern, Fixed yolk, no speedo gear, with torque converter and flex plate.
Look in the FE forum for free FE parts. Exhaust manifolds and heads
I would rather see the items get used instead of being scrapped
I'll add as I find more items.
Everything is located in San Jose, CA
Ken
Old Dec 4, 2009 | 02:26 PM
clutter's Avatar
clutter
Sure wished your location said GA instead of CA.
Old Dec 4, 2009 | 06:41 PM
50t16t's Avatar
50t16t
free parts
is the trany a long or short tail housing ???
Old Dec 4, 2009 | 07:11 PM
woods's Avatar
woods
I think it is considered a short tail shaft housing.
It is a 4X4 version. Same as a standard fixed yolk tail piece but the speedo input wasn't drilled. The spot was casted but never drilled.
Old Dec 4, 2009 | 08:19 PM
50t16t's Avatar
50t16t
free parts
If I send you the money will you ship it for me and can you post a pic thanks.
Old Dec 4, 2009 | 09:10 PM
woods's Avatar
woods
Where are you located?
I can send the tranny or the tail shaft assembly.
I think this one can be removed without full disassembly.
The tranny will need rebuilt. It was slipping a little when I pulled it.
Converter also? the converter is pretty heavy on its own.
I will tryto get a picture or 2 this weekend
Old Dec 4, 2009 | 09:32 PM
50t16t's Avatar
50t16t
free parts
OK, I realy just need the tail housing but if its for a big block I would like the trany but without the converter. Thanks I'm in So. CAL.
Old Dec 4, 2009 | 09:42 PM
woods's Avatar
woods
It's for a FE big block.
I will check this wekend to see if it will separate. I think early ones will pull off but I think newer ones have an inner retainer clip.
I rebuilt a C-6 for the truck and the assembly removed complete when disassembly.
Old Dec 5, 2009 | 12:00 AM
50t16t's Avatar
50t16t
free parts
Sorry but don't know what FE stand's for.
Old Dec 5, 2009 | 12:10 AM
woods's Avatar
woods
FE engines are 352, 360, 390, 410, 428, There are a couple other commercial engines.
Nothing interchanges between them and other Ford big block "429,460"
but internal C-6 parts are all compatable other than the main housing.
Old Dec 15, 2009 | 08:31 AM
woods's Avatar
woods
Sorry for the delay,
The wife has Me busy with the holidays.
I'll try to pull the assembly off this weekend
Old Dec 15, 2009 | 08:54 AM
carpenter547's Avatar
carpenter547
hey woods you got any cam shafts laying around in there? good ones for towing not hot rodding?
Old Dec 15, 2009 | 09:17 AM
woods's Avatar
woods
Not anymore.
Had a Crane 904 sitting hare for a while but it's gone now.
skelco
New Member Introductions
Oct 5, 2013 09:56 AM
dogluvr
18
Jun 24, 2013 06:41 AM
woods
15
Nov 30, 2009 11:14 AM
Nighteyez
N. California Chapter
54
Jan 21, 2007 07:55 PM
woods
Jun 18, 2006 08:54 PM
