front end
Old Dec 2, 2009 | 08:35 PM
jeffkobylanski's Avatar
jeffkobylanski
front end
i am going to change my front end on my 1975 f-250 from drum brakes to disc brakes and i need a front end and what will inerchange and any modifications that will help the change out.
Old Dec 2, 2009 | 09:13 PM
Ford6.02005's Avatar
Ford6.02005
Assuming you have a 4x4 the most logical swap would be a 1976 or 1977 F-250 disc brake front... it will literally bolt in. Brake hoses,master cylinder,and metering valve will need to be changed also.
Old Dec 2, 2009 | 09:22 PM
montana_highboy's Avatar
montana_highboy
You might want to consider pulling an axle from a 77.5-79 F250 and get the added benefits of a high pinion axle along with the disc brakes.
Old Dec 3, 2009 | 09:10 AM
mark a.'s Avatar
mark a.
I would go with the high pinion too. Drive shaft will have to be modified but a lot better drive shaft angle. Spring pads are the same width. I would also get the steering box from the 77.5-79 and graft it in at this time as well.
Old Dec 3, 2009 | 09:19 AM
dhobdey1's Avatar
dhobdey1
I am currently in the process of doing the exact same thing, From the suggestions of members of this forum, I purchased a 1979 F250 4X4. I removed the axle from my 1975 F250 4X4 and am doing the swap, removing the axles was easier than I thought it would be. One thing I'm doing right now is changing the gears in the front differential from 3:54 to 4:10's to match my existing rearend ratio. I purchased these parts from Jeff's Bronco Graveyard for under $500.00, which also includes a trac lok so I will have both front wheels pulling at the same time. Should be a good setup. Too bad the donor truck I bought did not have the same ratio as my truck, but oh well. I also am getting rid of my power assist steering setup and am switching the power steering over to the 1979 Integral setup. There has been a lot of artcles and pictures describing these swaps in this forum and I am grateful for the help of these members. Good Luck in your project and don't be afraid to ask questions on this forum as these members are very helpful.
thinksnow
Jul 30, 2011 09:27 AM
my 66
May 20, 2011 11:09 PM
greenterror
Jan 14, 2008 07:53 AM
greenterror
Mar 20, 2007 08:30 AM
JByrd1173
Jul 5, 2004 08:55 AM
