I changed my rear brakes two weeks ago. The gap to get to the inside nut on the slide pin is narrow and non of my open end wrenches would fit in. I ended up pulling the whole caliper off. Tomorrow morning I am doing the braked front brakes on my wifed Expy EL. It seems to have the same brake set up. Does anyone know what size that wrench is. I just assume go to sears and buy a narrow wrench that size tomorrow.
I believe I used a metric socket on the slider pin bolts. Try sticking a screw driver into the gap to jam the nut from turning then just back the slider pin out.
Had this conversation a couple weeks ago. I expected everything to be metric on this truck but the bolt heads on the caliper slide pin/bolts are 5/8in.
also the method I use works great and saved a wrench from the grinder
