BEST WAY TO CLEAN ENGINE??
Old Nov 30, 2009 | 10:03 PM
yeahbuddy24's Avatar
yeahbuddy24
Ok i was wondering what the best way to clean my engine is. I dont think powerwashing is a good idea because of the high pressure. What do all of you use and any special techniques that i need to know of? My buddy powerwashed his engine awhile back and it turned out to be a bad idea on his part as he had electrical issues afterwards. The reason i am doing this is i have developed a small ticking sound not sure what it can be but i dont want to get any derbis in my engine as i will be pulling valve covers and all that.
Old Nov 30, 2009 | 11:06 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Pressure washing is fine, the main thing is to avoid (or even better cover) the distributor so it doesn't get soaked.
Other than that blast away.
Josh
Old Nov 30, 2009 | 11:15 PM
bulletsneverlie's Avatar
bulletsneverlie
I tried power washing. Doesn't do alot with a greazy motor. Steam/hot water under pressure works better. If it gets in the dist, take off the cap and dry it out w/ paper towels.
Old Nov 30, 2009 | 11:20 PM
FLATFORD1976's Avatar
FLATFORD1976
A good degreaser is a must. Once you get it clean SIMPLE GREEN works great for keeping it clean. Full strength though. Don't dilute it. It works great on my chrome valve covers and aluminum intake. I just spray it on and rinse it off.
Old Nov 30, 2009 | 11:22 PM
FLATFORD1976
Wd-40 works great on a soggy dist. as well. Pop the cap spray a little in and you are good to go.
Old Nov 30, 2009 | 11:24 PM
OrangeJuice's Avatar
OrangeJuice
I've used a pressure washer before on an engine before, but you have to use some sort of degreaser and let it sit a while to cut the crud. What I did was cover the distributor and other electrical components with some old sheets of plastic. After cleaning it I grabbed my air compressor and blew off any remaining water that may cause a problem. Then took it for a test drive to make sure it didn't drown to death...lol.
OJ
Old Nov 30, 2009 | 11:25 PM
Bullitt390's Avatar
Bullitt390
You guys don't have hot water at your car washes? The ones around here have an engine degreaser setting (low pressure soap) and then you switch to either high pressure hot soap and then high pressure hot rinse.
Works awesome!
Josh
Old Nov 30, 2009 | 11:27 PM
OrangeJuice
Some pressure washers have a built-in siphon for just this to spray the degreaser as you work...a handy feature.
OJ
Old Nov 30, 2009 | 11:29 PM
OrangeJuice
Hot water? Sure, can always hook it up to my hot water tank in the garage. Done it before. Works good.
OJ
Old Nov 30, 2009 | 11:39 PM
lowriderf100's Avatar
lowriderf100
Its a little costly but carb cleaner or brake cleaner is the best. And the extra that you spray evaporates fast.
Ofcoarse thats my .02 cents
Old Nov 30, 2009 | 11:49 PM
yeahbuddy24
Should i keep the engine running while i do this or should a keep it shut down? I have a good idea of what im going to do now Thanks.
Old Dec 1, 2009 | 01:06 AM
Kalve's Avatar
Kalve
greased lighting that you get at lowe's works great also the greased lighting walmart carries works real good used them on other vehicles. I cleaned the engines with that an one of those shower wands like walmart carries an a brush did not mess anything up on it.
Old Dec 1, 2009 | 01:59 AM
bulletsneverlie
Generic oven cleaner works really good for grease (fake Easy Off). I think it's pure lye. Careful though, it will peel cheap spray paint.
The one at the carwash with the heat and degreaser already in there is the easiest.
Old Dec 5, 2009 | 10:08 PM
1977f250's Avatar
1977f250
I have had good luck with Gunk foaming degreaser. Drive to car wash let engine get warm, pull in and spray it down with the Gunk while it is still warm. I bag the dist cap, start it up and spray away. Works really good when hot and hot water to spray with. Of course I go there at night, the guy gets freaked out seeing you do it in the day.
Old Dec 6, 2009 | 01:31 PM
GQROD's Avatar
GQROD
Good old fashioned GUNK brand engine degreaser, i don't use the gel so i don't know how good that works.
DO NOT USE walmart brand degreaser it will ruin your plastic parts with a hazy film that does not come off.
Simple green BE CAREFUL do not get it on painted parts or it will strip the paint and remove the gloss.
You may need two cans of GUNK but it works great, also Windex for the plastic parts and Fantastik for hoses.
