weird whistling osund when excelerating???
Old Nov 30, 2009 | 08:37 PM
stx4x4's Avatar
stx4x4
I have a 04 stx 4x4 4.6 v8, great truck, had it for about 5 years, have a edge tuner , magnaflow muffler. in the past few days been getting really cold here in illinois, i kow my belts will make noise till it warms up, but then when driving later, everytime i give it gas i hee a small light whistling sound, when im not giving it gas it goes away, when i gas it comes back, anyone have any ideas???
Old Nov 30, 2009 | 10:56 PM
camohr's Avatar
camohr
Cold air intake?
Old Nov 30, 2009 | 11:04 PM
GwarForAll1021's Avatar
GwarForAll1021
my aftermarket radio whistles just a tiny bit with the motor.
its so cool its like a tiny pretend supercharger! just cant have the volume up/
Old Nov 30, 2009 | 11:09 PM
camohr's Avatar
camohr
sounds like you have a bad ground somewhere
Old Dec 1, 2009 | 09:30 PM
2004 xlt 5.4's Avatar
2004 xlt 5.4
I also had this problem when it starts getting cold,
A lot of the problems seemed to be the alternator. Mine was and had it replaced under my extended warranty . if you still have warranty, get the alternator checked an replaced. If you don't have warranty, go get a new alternator and replace it. It will more than likely fix your problem.there was also a TBS on it
Good luck!
Old Dec 1, 2009 | 10:48 PM
stx4x4's Avatar
stx4x4
Good luck!
thanks for the advice, going to dealer on friday, i tried to find the TSB on it, couldnt find it, have any clue whre i might findit ? thaks
Old Dec 2, 2009 | 10:26 AM
2004 xlt 5.4
Found it on an older site
TSB-08-4-2
Cold Start Fead Hoot-Whistle Noise-built before 1/c
Pub. Date Feb 7, 2008
F150
5.4 and 4.6 engines built before 1/28/08 may exhibit a front related high pitched metallic whilstle/hoot noise after a cold soak 4.4 C. Noise may be caused by the grooved nylon FEAD idler pulley.
Service procedure to correct. Replace the nylon FEAD idler pulley 6L3Z-6C348-A Idler Pully.
not sure if changing the pulley is the best thing
I would get a new alt. put in it worked for me.Had 80,000 klm when changed now 130,000 and 2 winters no problem.
Old Dec 3, 2009 | 02:47 PM
barecove's Avatar
barecove
I too have this... only when cold... I do have a CAI... I just ignore it till the engine warms up and it goes away.... I did see the TSB on the alternator... strange that that could be the culprit....last thing I would have thought of
Old Dec 4, 2009 | 11:05 PM
stx4x4's Avatar
stx4x4
well took it in to the dealer today, they has to replace the tentioner pully and replace the belt, all 278.00 dollars, but its quite and runs good, think the belt was going , now it feel like it has no sliping then before
Old Dec 5, 2009 | 09:10 AM
week0019's Avatar
week0019
Good luck!
Same here. In cold weather I had the whistle. Replaced the alternator and no problems since. This was about two years ago.
Old Jan 7, 2010 | 09:10 PM
dtingle89's Avatar
dtingle89
ROLL YOUR WINDOW UP!!!!!
Old Jan 9, 2010 | 06:01 AM
60DRB's Avatar
60DRB
well this is certainly an odd thing. I've been hearing a similar noise with the cold (1st winter with this "new" used 06/4.6). I was thinking along the lines of the vent system in the cab or radio feedback noise.
So the noise is a cold tensioner pully? Too wierd. It goes away pretty quick while driving.
Old Jan 9, 2010 | 10:46 AM
2004 xlt 5.4
Or the alternator
Old Jan 9, 2010 | 03:05 PM
60DRB's Avatar
60DRB
I'm trying to believe it's the cheaper fix, but it seldom is...
Old Jan 9, 2010 | 04:20 PM
bobskido's Avatar
bobskido
I also have the same thing. It is coming from my K&N cold air intake.
