Sponsored by: Real Truck
o2 sensor bank 2
Old Nov 29, 2009 | 07:53 PM
kelly67's Avatar
kelly67
o2 sensor bank 2
I tried to search but came up with a 1,000 threads an nothing to do with o2 sensors! Check end light came on. Took it to have computer read at auto store and it came up p0174 bank 2 eng running lean. my question is, is the bank 2 the passenger side o2 sensor? I believe i'm correct put want to make sure. the sensor they gave me is identical except wire harness is shorter but will still work. An just my luck I pull the old one out and it striped on the way out. I checked threads on exhaust pipe and there good, thank god. didnt want to go down that road. i still am going to try and get thread pitch and buy a tap if i can find one just to be on safe side. only 60,000 on her so i may be doing this again.
Old Nov 29, 2009 | 07:59 PM
06silvercrew's Avatar
06silvercrew
Nope 1234 on pass side 5678 on drivers so drivers is bank 2. And chances are an H02 sensor wont fix your problem. Its doing its job reporting a lean condition, you prolly have a vacuum leak somewhere or something else.
Old Nov 29, 2009 | 08:06 PM
kelly67's Avatar
kelly67
ok then can you tell me are the o2 sensors bank1 &2 the same because know i have to replace the pass one its stripped! I didnt put the new one in so i will exchange it tomorrow. any idea on a place to start for vacuum leak?
Old Nov 29, 2009 | 10:12 PM
kelly67's Avatar
kelly67
just curious but how would a vacuum leak give me a lean condition on the bank 2 side is this possible?
Old Nov 30, 2009 | 01:23 AM
KhanTyranitar's Avatar
KhanTyranitar
Well for starters, depending on where the leak is, it can affect just one side. A bad O2 sensor will not typically cause a leak code. Bank #1 is the passenger side, bank #2 is the driver side. Look for vacuum leaks. A misfire can also set a lean code, especially if it is lean enough to cause the misfire. A bad MAF can also cause lean codes, as can a weak injector. There are so many possibilities here. All I can say for certain is that replacing the sensor will give you a known good sensor, but it is very unlikely that it will fix the problem. More involved real world diagnostics need to be done, otherwise you are going to throw a lot of parts at this and still not fix the problem.
Old Nov 30, 2009 | 07:43 PM
06silvercrew
Yupp, MAF will generally give you lean/rich codes on both banks, not just one. Could be a leak at the intake where it meets the head etc.
Old Dec 2, 2009 | 08:14 AM
kelly67's Avatar
kelly67
well thanks to a local garage that let me borrow his tap for the o2 sensor i'm back to square one. well i know now what side bank 1&2 are and bank one has a freshly tapped hole an new o2 sensor. As my luck would have it in the middle of doing this my car blew a brake line and my jeep sprung a small leak in the radiator.so i'm going to fix the other 2 and get back to this in a few days.
Old Dec 2, 2009 | 11:38 AM
kelly67's Avatar
kelly67
ok since i was back to were i started with eng light on i decided to reset computer to see what it did. it stayed off when i started it. the one thing i did that day was it had just rained and there was alot of water on the roads. not sure if this might have tripped the light or why put i'll run it the next 3 days to work to see what it does.
Old Dec 4, 2009 | 10:30 PM
kelly67's Avatar
kelly67
well 3 days of running approx 175 miles the eng light did not come back on. I will keep watching it.
Just curious what does MAF stand for? have not heard of that abbreviation.
Old Dec 4, 2009 | 10:41 PM
redford's Avatar
redford
FTE Leadership Emeritus
Mass Airflow Sensor. It is a large sensor at the input side of the intake manifold that measures how much air your engine is sucking in at any given moment.
F150Terry
2009 - 2014 F150
Jul 17, 2019 10:50 PM
pnp522
Modular V8 (4.6L, 5.4L)
Jul 15, 2015 04:40 PM
Mass928
18
Jul 11, 2014 08:19 AM
demond25
Feb 16, 2013 11:37 PM
terrysumner
Jan 19, 2011 09:21 AM
