O2 sensor bank one
Old Jun 11, 2015 | 08:27 PM
pnp522's Avatar
pnp522
O2 sensor bank one
My brother has a 98 E250 with a 5.4. It has a code that says O2 sensor bank one is running lean. Which side is bank 1? He has a Haynes manual and it doesn't say which side is bank one and I haven't been able to find out with a search.
Thanks for any help.
Old Jun 11, 2015 | 08:49 PM
projectSHO89's Avatar
projectSHO89
Lean codes are not caused by the O2 sensors.
Old Jun 27, 2015 | 12:35 PM
mse871859949's Avatar
mse871859949
bank 1 is pass side, same as Cyl 1
Old Jul 15, 2015 | 04:40 PM
Man_tlac83's Avatar
Man_tlac83
A few things can contribute to this code. Vaccum leaks, pcv not working (shack it. If it rattles it should be good). Grommet that holds the pcv could be done. Clogged injectors. I had code P0171 on my 01 5.4 with 239k. Is that the code your brother has? Also I read someone on this forum that a clogged fuel filter "could" cause this.
Wishing you the best of luck. Remember the search feature can be your best friend.
RJ3
Modular V8 (4.6L, 5.4L)
Aug 27, 2017 01:00 PM
mizzourover
2009 - 2014 F150
Apr 14, 2015 09:28 AM
slcdzl
Oct 20, 2010 02:00 PM
popdaddio
1997 - 2003 F150
Oct 4, 2006 02:58 AM
wipper
Jan 4, 2005 11:29 AM
