The motor mount towers are the same. I did this conversion in my 82 bronco and if I remember right i did not have to do any major fab to do it. Everything pretty much dropped in. mine was a 351w to a 400m swap. hope this helps.
i would do the 400, its the same block but you get more cubes cheap, slap some better flowing heads to take advantage of the added stroke, you got a rocket, a big ugly heavy gas filled rocket
The transmission will come with the torque converter if you get a used one. If you have any questions of what will interchange, just go to a site like autozone or napa, and plug in your truck and see what the part number is, and then plug in a 1980 truck with a 351m and see if the part number matches(starters, flexplates, torque converters, motor mounts, etc.)
If you get a used tranny, the first thing to do is to pull the torque converter out and replace the front seal. The torque converter sags when it's not installed and usually ruins the front seal of the tranny. When you re-install the torque converter, make sure you push and turn and push and turn many times to make sure you have it engaged all the way into the tranny.
I hope the 351m was from a 80-up truck and has a rear sump oil pan or you will need to round those parts up. You will also need to get a new y-pipe, and if it was from a truck, it should have the correct exhaust manifolds, otherwise....this free engine is not so free anymore is it?
