i dont use glow plugs any more cause all i do is burn the tips off mine, but im running more timing/fuel/rpm then international ever intended on happening, i have beenrunning the glow plug "delete" mod which is just cutting the tips off the glow plugs so its like having a plug inthere which takes up less spce, so that lowers the compression, only downside is you have to find a way to crank it, a little wiff of either does the trick, but i want something better, and as soon as i get my hands on a 1999-03 7.3 powerstroke intake heater, im going to rig it up on my idi
dyoung we need to figgure what is burning yours up as timing fuel and rpms should not effect your plugs it would also be melting your pistons.
