Glow Plug Brands
Old Nov 28, 2009 | 11:17 PM
Coolball's Avatar
Coolball
How does a glow plug go bad? I hooked up one today to the battery and grounded it on the radiator support and it got hot and the tip actually started to deform. Guess it wasn't what I thought it was...I mean with the name glow plug I expected to see that thing red hot but no dice.
Old Nov 28, 2009 | 11:21 PM
wreckinball's Avatar
wreckinball
what brand was it? If it was motorcraft beru it wouldnt have deformed. I have yet to see one ever deform. They will burn out after about 30-60 seconds continuous but they wont deform. If you did that, i would bet you had autolite or bosch.
Old Nov 28, 2009 | 11:47 PM
Coolball's Avatar
Coolball
Brand was the AcDelco type and I will mention that the ones I originally replaced were Autolites which a few were swollen and also on one the tip was mangled as in deformed. What a pain to get the old ones out. I'll be getting the Beru plugs next time it's time to change them all that's for sure. I only held the plug grounded for about 15 seconds and that was enough to do it and since I wasn't getting the glow expected couldn't tell what was going on. You can bet I wasn't going to grab it to find out! lol. But I did meter the resistance to see if it was changing while heating and it did a little bit, something like 2 ohms. Curiosity killed the cat and the plug in this case.
Old Nov 29, 2009 | 12:38 AM
wreckinball
There is no way to burn proof a plug but they can be made to a standard that eliminates swelling and deforming. The acdelco brand is produced by autolite for some applications i believe. Either way, they are both crap and so is bosch. Berus all the way.
Old Nov 29, 2009 | 07:46 AM
tjc transport's Avatar
tjc transport
i ain't rite
Originally Posted by fixitman1310
i have 1 auto lite stuck in the hole it screws to the last thread and wont pull out of
hole. it just wabbles. any ideas on getting it out
thanx
steve
depending on what cylinder it is in and if you can get a cordless drill on the end of the plug,i spray the threads with pb blaster, then spin the glow plug slowly with the drill as i gently pull up. then i will push the plug back down a bit and respray it, and start again. i repeat the spray/spin/pull until i get the plug out.
this shaves a little bit of the swollen tip off as you are pulling it up until it comes out.
i have used this method of removing stuck glow plugs over a dozen times, and have gotten every one out that i have used it on.
remember though, patience is the key. if you rush it, you will snap the tip off, and then you will be pulling the head.
Old Nov 29, 2009 | 09:00 AM
Dave Barbieri's Avatar
Dave Barbieri
If your batteries are good and your connections are clean and tight, a glow plug will do what its name sez: it'll GLOW. Red hot. This is where needle nose pliers come in REAL handy! GP's go bad because the internal resistance increases to the point that they don't glow anymore. They just get 'warm' or 'hot' (sorta). To start an IDI motor on a cold morning, they need to GLOW. If the GP's are removed from the head, you can do the 'hook it up to the battery and watch 'em glow cherry red' test. If they're installed, you can also test them in place by reading resistance from the connector to the cylinder head/block. According to the Ford shop manual for the 6.9, good GP's will show 1 ohm or less. I tried reading resistance on several new ZD-9's and sure 'nuff, each one read exactly 1 ohm.
Old Nov 29, 2009 | 11:32 AM
Dave Sponaugle's Avatar
Dave Sponaugle
With a good meter you will actually be seeing .5 ohm's on new glow plugs.
Old Nov 29, 2009 | 11:55 AM
Coolball's Avatar
Coolball
I've only got a digital Radshack meter and all the plugs read open as in no reading when read between the connector and the hex part of the plug. Could it be that all new plugs have gone bad in a couple weeks? Guess it's time for a cheap test light.
Old Nov 29, 2009 | 03:15 PM
tjc transport
i ain't rite
i have seen ac delco and autolight plugs burn out after one start.
Old Nov 29, 2009 | 05:01 PM
dyoung14's Avatar
dyoung14
i personally had 1 set of glow plugs burn out after 2 cranks and they were motorcraft, never held longer than 10 seconds both cranks, 2 plugs were swelled when i pulled them, both broke off in the head
Old Nov 29, 2009 | 05:32 PM
Dave Barbieri
Now THAT's a cool idea!
Old Nov 29, 2009 | 11:22 PM
Dave Sponaugle
Doug you are the only person that has had that problem since I have been reading this forum which is about 8 years ago now.
Old Nov 29, 2009 | 11:39 PM
  #28
wreckinball
Yeah you would be the first in that department. I installed a complete set of bosch plugs and it started perfect once, then the second time it failed to start. Every damn plug failed. i am just glad they didnt swell.
Old Nov 30, 2009 | 10:40 AM
  #29
Dave Sponaugle
A couple posts back someone asked about how they fail.
A glow plug has a heating element, sort of like a light bulb.
And just like any element they will eventually fail.
Also just like any element they do degrade with every heating cycle and become less effecient.
A new plug with a good meter will ohm out at .5 ohms.
So with 12 volts applied it will draw 24 amps of electricity.
As you use them the resistance starts to increase.
By the time the plug has 1 ohm od resistance, the amps drawn are down to 12 amps.
So now the plug is making 1/2 the heat it was when it was new.
Also with the new style controller on the 87 and newer engines, the increased resistance starts to affect the glow time, since it is controlled by the resistance feedback from the glow plugs.
That 1/2 as much heat will also make it harder to start the engine as temps get colder.
Old Nov 30, 2009 | 11:26 AM
  #30
9473's Avatar
9473
Thanks for the info Dave. Is there a better system that could be installed? It is really all about just getting her started. I remember during her younger years she would start at -20F without the block heater (no access to elec.).
BTW do I need a certain number of posts before I can get access to edit signature? I don't have edit sig option. Thanks...Scott
