2000 7.3l excursion California model help
Old Nov 28, 2009 | 07:35 AM
muddrag1's Avatar
muddrag1
I have recently bought a 2000 7.3l excursion that is a california model. I am having a starting problem. It doesn't do it all the time. It is random. Whats happening is you will get in to start it. It will turn over but will not fire. The SES light comes on then goes off. The wait to start comes on then goes off. The PATS theft light comes on then off. When cranking over the rpms do rise. If i keep trying for about 5-10 minutes it will start. It doesn't have a glow plug relay. It has the glow plug module. I have changed the relay for the IDM. I also took it in for a diagnostics and they found nothing. I am at a loss and need to figure this out. I will eventually get a P1670 code. But it will go away. Please help!!!!!
Old Nov 28, 2009 | 05:22 PM
Stewart_H's Avatar
Stewart_H
Bump to the top.
Is that the only code you're setting? Do you have a fuel pressure gauge installed? When was the last time you changed your oil?
Who did you take it in to for diagnosis?
Stewart
Old Nov 28, 2009 | 06:14 PM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
Have you checked your HPOP reservoir level? Make sure it is about an inch or so from the top.
Old Nov 28, 2009 | 08:22 PM
sandmn1010's Avatar
sandmn1010
I beleve california trucks will throw a code if one or more glow plugs is failing, i guess the glow plug module has a logic to monitor glow plug operation. Hope that helps.
Old Nov 28, 2009 | 08:26 PM
F350-6's Avatar
F350-6
When it doesn't start, is there any correlation to the engine or temps being cold or hot? When you're cranking and it won't start, is there any smoke coming out of the tail pipe? When you're having this no start issue, can you hear the fuel pump humming for 25 seconds after the key is turned on?
Old Nov 28, 2009 | 09:27 PM
GOT 7.3 ?'s Avatar
GOT 7.3 ?
Do you have any mods on the truck. Specifically something like an Edge tuner? It has issues sometimes. There is a pats sequence you have to do to get truck to start, but only if you have changed your programming recently.
Old Nov 28, 2009 | 09:47 PM
muddrag1's Avatar
muddrag1
The only mods to the vehicle is an upgraded intake and exhaust. There are no program changes or tuners. That is the only code I am getting. It doesn't matter on temp. I am going to check the hpop my next days off of work. I do hear the fuel pump running. And there is no smoke at all when this happens.
Old Nov 29, 2009 | 09:39 PM
muddrag1's Avatar
muddrag1
So this morning I had to run somewhere after I got home from work. And sure enough the excursion died on me. This time it wouldnt restart. Went to bed wife tried to start later, still nothing. When I got up I checked the hpop level and it was low. Filled it up and it fired right a way. What would cause this level to drop.
HollowayDoc
32
Mar 20, 2015 03:49 PM
lancekilgore
Dec 12, 2012 10:43 AM
Turfzilla
Nov 2, 2012 03:06 PM
cowboy51
21
Mar 27, 2007 10:18 PM
7.3anda6.0
Nov 7, 2006 09:17 PM
