Boost gauge not working
Old Nov 27, 2009 | 10:15 PM
aaron4vt's Avatar
aaron4vt
I am working on my dads 06 F350. He had four dash lights go out, so we changed out the bulbs and put the dash back together. When we hooked the batteries back up all the gauges reset except the the boost gauge. The needle went way past 0 and bounced for about 2 seconds then it just stayed below 0. We have tried to reset it by unhooking the batteries and turning the ign. switch on and off several times. Always go back past 0 and stays there. It does work it just doesn't read correctly. I am pretty sure that the needle did not get turned on the shaft? Is there a way to reset it?
Old Feb 28, 2016 | 12:28 AM
Solamia's Avatar
Solamia
Sorry no one got back with you. Did you get it figured out? My boost guage is sitting below zero and not moving no matter what.
Old Feb 28, 2016 | 01:07 AM
killerstroke's Avatar
killerstroke
Hold the trip button in and turn the ignition on, see if the boost gauge sweeps properly like the other ones. If not, you have a cluster problem.
Old Feb 28, 2016 | 07:18 AM
WatsonR's Avatar
WatsonR
7 years with a cluster problem has to be a record for sure!!
Laggy
17
Sep 23, 2021 03:14 PM
gearloose1
Jan 1, 2020 05:03 PM
bthr22
Dec 23, 2016 09:56 AM
sherrijaaf
6.7L Power Stroke Diesel
Apr 25, 2016 10:16 AM
hairymonster
Mar 9, 2016 09:02 AM
