95 Headlight switch
Old Oct 2, 2007 | 10:26 PM
Shadowrider123's Avatar
Shadowrider123
95 Headlight switch
Had to re-register, didnt recognize me under my Lizardking username.
The **** on my 95 f150 headlight switch will not stay on.
Does the **** pull off the shaft, or is it permantly attached to the shaft?
If its not susposed to come off I can epoxy it back on.
Can I replace just the ****, the switch works fine, if so, where do I find just the ****?
PITA having to carry a pair of pliers to turn the headlights on.
Old Oct 2, 2007 | 10:32 PM
quicklook2's Avatar
quicklook2
the **** and the rod are released by a pin right at the bottom of the ****.
use a small screwdriver.
Old Oct 2, 2007 | 11:34 PM
Skandocious's Avatar
Skandocious
QL let me correct you. The **** only released by that small metal tab at the bottom of the ****. You use a screwdriver to push the tab toward the rear of the truck and it will slide off. You might be able to bend the metal tab back down to make it grab the rod again, otherwise you'll need to replace the rod. I believe there is a release for it near the actual switch in the dash. You don't want to epoxy it because you need to pull that **** off in order to get the dash off
Old Oct 3, 2007 | 07:34 PM
lostin90s's Avatar
lostin90s
I have seen **** and clips in fixit isle (not stock ) The clips on em has been same for years . But I just save em from parts trucks . You can glue it on . But look for **** for future reference. . Because you will have too crush and break **** off to work in dash later. I ha
Old Oct 4, 2007 | 07:12 AM
jroehl's Avatar
jroehl
If you glue the **** back on, and need to work on the dash, then you just have to release the shaft instead. I believe the stealerships sell them as an assembly (**** and shaft), I had to replace one once.
Jason
Old Oct 4, 2007 | 07:34 AM
ccecilm2's Avatar
ccecilm2
The wiper **** on my '84 would not stay on because the plastic was hole in the **** was wallered out and just turned around the metal clip. I took it off, dropped some gorilla glue in the hole, inserted the metal clip back into the **** and let it set 24 hours. I then took a dental pick and dug the excess glue out from the hole so the clip would slide onto the shaft. Has been working great for years now.
dacv01
Jul 8, 2013 08:25 PM
xc4jokestomper
May 21, 2011 09:02 PM
Danny Stroup
Nov 30, 2009 04:10 PM
dhobdey1
Nov 28, 2009 08:39 AM
MintFord
Dec 23, 2006 07:57 PM
